Old 10-16-2012, 08:35 PM   #1
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
DBA T3 rotors fitted
I spent a bit of time today to fit up DBA's OEM replacement sized rotors to the FR-S. These are their latest 4000 series Club Spec T3's, and are a direct bolt on. It's a fairly easy job, though you'll wish for another pair of hands when bolting the calipers back on, they are heavy! As a bonus, these weigh 16.55lbs (as per the UPS scale) vs. the stock units 16.95 lbs. Less unsprung weight is nice!
Initial impression after some bedding in is that they do definitely give a better initial bite, and threshold braking was improved a bit as well. I'll be giving them a more severe thrashing in the future, especially once the turbo kit is in.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
86drift (10-16-2012)
Old 10-16-2012, 08:54 PM   #2
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Very nice! Any plans to try the 5000 series rotors out? Very pricey, but I'm curious how much additional weight could be saved with the 2-piece rotor design.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-16-2012, 09:00 PM   #3
AVOturboworld
I'm sure we will in the future, but wanted to try these out as they are a more reasonably priced "replacement" rotor, and it's a direct swap in without even needing to remove the brake pads.
Old 10-16-2012, 09:41 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Good choice. We have them on ours as well. DBA makes a quality rotor.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
ajc209 (03-16-2015)
Old 10-17-2012, 05:10 AM   #5
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I just gotta say, good choice in rotor selection :P
Great news that they are lighter than the OEM rotors too.
stevo_12v is offline   Reply With Quote
Old 10-17-2012, 01:39 PM   #6
TAP Auto Parts
Drives: FRS
DBA makes great quality rotors.
TAP Auto Parts is offline   Reply With Quote
Old 10-18-2012, 05:46 AM   #7
OrbitalEllipses
Drives: Attitude
$800 and minimal weight savings, at least in WRX spec (thin Al hat, heavier ring to make up for it).
Old 10-18-2012, 10:48 AM   #8
canu_50
canu_50's Avatar
Drives: Scion fr-s
The 5000 series is not just about the weight saving. On our evox Race car, they are the only one with the performance friction 2 piece disc that can hold up almost a year of beating with race pad. The heat dissipation is great on those rotors, i might put them aswell since i have couple of set in stock.
canu_50 is offline   Reply With Quote
Old 10-18-2012, 11:40 AM   #9
AVOturboworld
Oh, no doubt about it - if you are racing frequently, the 5000 series are great. When I was at the track far, far more often in Japan with my twin turbo and then twin scroll Legacy, the 5000's held up to punishment for far, far longer than any other rotor. And that's a much heavier car. Doing the back straight at Twin Ring Motegi, going down the hill, the shedding about 100km/h for the right hander was guaranteed to stress any rotor/pad combo, and the 5000's flew through that with no issues.
Old 10-18-2012, 12:16 PM   #10
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
they look great, what pad are you running? still factory?
VSGTS14 is offline   Reply With Quote
Old 10-19-2012, 12:07 AM   #11
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Nice, those look awesome on the car. I have always run DBA rotors and have always been very impressed with them. I am curious as well if you went with an aftermarket pad or kept the stock ones.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 04-16-2013, 02:28 PM   #12
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
How would this compare to the DBA t2 rotors, Is there a huge difference between them to justify the price difference
vignesh is offline   Reply With Quote
1st FR-S TRD Kit fitted w/jdm lights SpecPer Cosmetic Modification (Interior/Exterior/Lighting) 160 09-08-2012 12:32 AM
OptionJDM - DBA Rotors OptionJDM Brakes, Suspension, Chassis 6 07-21-2012 11:50 AM
Anybody fitted any STI bits yet ICantAffordAnLFA BRZ First-Gen (2012+) — General Topics 4 07-12-2012 07:59 PM
DBA 4000 T3 Slotted Rotors for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-07-2012 12:41 AM
What options can be dealer fitted to the GT? kharn83 AUSTRALIA 28 06-06-2012 07:43 PM
