Old 11-25-2012, 12:43 AM   #1
Derrick
Derrick's Avatar
Drives: FR-S Raven
Excessive smoking from left exhaust?
So after driving my car from point A, to point B. (Example: home to work),
once I park my car, the left muffler seems to be outputting smoke, this happens for a good 1-2+mins out of only the left one. I compared this to other cars that my family drives but their car seems to have no smoke out of their exhaust after parking. The smoke is a clear white smoke, so it is very visible when you look.
Is this a problem I should be concerned about?
I do not smell any burning while driving.
I would take a video, but the smoke does not show on my camera. (iphone)
Edit: no fluids are leaking from what i can tell from underneath the car
Derrick is offline   Reply With Quote
Old 11-25-2012, 12:47 AM   #2
cnk
Drives: '13 DGM BRZ Limited
Based on the fact that you're in Vancouver and it's pretty cold out now I would say it's just water vapor since you say it's odorless. Check your fluids, i.e. oil, coolant, and if you don't see the levels decreasing by any significant amount, you should be fine.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
Derrick (11-25-2012)
Old 11-25-2012, 12:49 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
^ I notice it all the time; it's just the cold weather and the fact that our boxer engine creates a lot of heat.
The reason for why more vapor/smoke is coming out from the left exhaust is because of the way the muffler routing is designed. (Left side being closer to the catback)
Don't lose sleep over it.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following 2 Users Say Thank You to DaJo For This Useful Post:
bestwheelbase (11-25-2012), Derrick (11-25-2012)
Old 11-25-2012, 07:37 AM   #4
roddy
roddy's Avatar
Drives: '13 Ultramarine
+1 to both comments above.
Smoking or Redding BRZ/FR-S Tail Lights DarrenDriven DIY (Do-It-Yourself) Guides 596 02-20-2021 10:11 PM
Tailight/Headlight Smoking? IloveBaldEagles Cosmetic Modification (Interior/Exterior/Lighting) 12 11-15-2012 11:20 AM
Single exhaust exit on left or right? Kuzuri Engine, Exhaust, Transmission 18 07-30-2012 03:53 AM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Excessive wheel weights? muffinman Other Vehicles & General Automotive Discussions 6 05-25-2012 09:59 AM
