Old 10-23-2012, 04:12 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
headunit size
i know our headunit is not a traditional size, but what are the dimensions exactly? looking to change it out without adapters on the sides
lbroskee is offline   Reply With Quote
Old 10-23-2012, 05:39 PM   #2
Gir
Gir's Avatar
Drives: 86 GT Manual - Sonic Blue
It's about 20mm wider then a standard double dinn, and a few mm taller.
Kenwood make a headunit that fits perfectly, model number KENWOOD DDX630WBT
Gir is offline   Reply With Quote
Old 10-28-2012, 04:58 PM   #3
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
where did you purchase that from?
briang0901 is offline   Reply With Quote
Old 10-28-2012, 05:04 PM   #4
Gir
Gir's Avatar
I got it from eBay. It was a really hard until to find in Australia. You might have a bit more luck finding around in the US.
Old 10-28-2012, 07:18 PM   #5
briang0901
briang0901's Avatar
I was hoping so but the only online sites selling I've seen are in India. I will check out some local stores this week in hopes of finding it. Thanks
Old 11-18-2012, 11:02 AM   #6
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
is this headunit applicable for U.S. spec vehicles? has anyone here had any luck in the USA with this?
mikeg7827 is offline   Reply With Quote
Old 11-19-2012, 01:55 PM   #7
flatline
I guess because I'm a new member, I can't start my own thread. I'm trying to figure out what wiring harness/spacers are necessary to mount an aftermarket double-DIN HU. I tried searching the forums but couldn't find anything relevant that looked helpful.
I found this on eBay, just wondering what other forumers used: http://www.ebay.com/itm/SCION-FR-S-2...336#vi-content
I just want the basics - plug-and-play (no splicing), and I'd like to retain the USB/Aux input if possible.
flatline is offline   Reply With Quote
Old 11-19-2012, 03:59 PM   #8
Gir
Gir's Avatar
That kit will work.
As for USB/Aux retention, you will have to modify your car and head unit. There is a DIY thread on the forums about it (I can't remember where).
FS: Stock Headunit Flawless22 Canada Classifieds 1 01-28-2013 12:07 AM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
WTB Besoke headunit jchall30 Audio/Visual, Electronics, Infotainment, NAV 1 09-26-2012 05:25 AM
At tip for the stock headunit neutral Electronics | Audio | NAV | Infotainment 6 08-26-2012 10:47 PM
FR-S headunit replacement drei CANADA 7 07-11-2012 04:08 PM
