Old 10-23-2012, 01:49 AM   #1
APS86
Drives: GTS86 Manual
ECU reset post aFe Takeda CAI install
Do you need to reset the ECU (by disconnecting the battery) post install of a cold air intake - I thought the ECU was "intelligent" and learnt on the fly???
APS86 is offline   Reply With Quote
Old 10-23-2012, 02:24 AM   #2
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
It smart to disconnect the battery. Also let it idle after you install and start the car. This ECU seems to be picky.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 10-23-2012, 02:30 AM   #3
APS86
thanks for that (good to see the thanks button is back) - interesting that I could not see that in the instructions suppled!
Old 10-23-2012, 06:16 AM   #4
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Yea its always good to reset the ecu and i agree with tim this ecu is picky.. what i do is disconnect for 20 mins then reconnect and let idle for 5-10 mins...it might not feel as responsive from the start but u have to do at least two or three drive cycles i think. I usually pick like a 15-20 mile destination drive there..shut the car off. turn it back on and let it idle for 5 mins again and drive back so that u've completed two drive cycles and u should start feeling the car being a little more responsive
brichard0625 is offline   Reply With Quote
Old 12-16-2012, 10:49 PM   #5
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
does it matter if you disconnect the positive or negative terminal? i cant seem to get the negative terminal off haha
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
TPMS reset charge FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-09-2014 01:22 PM
ECU reset after Break-In paros28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-19-2013 05:41 PM
Bluetooth causing head unit to reset? Eric1855 Electronics | Audio | NAV | Infotainment 4 01-15-2013 08:42 PM
Miami dealer for TPMS reset yomny Southeast 3 10-09-2012 11:17 AM
Takeda intake by afe FrsSwag FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 06-27-2012 03:27 PM
