Old 10-21-2012, 10:01 PM   #1
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
How do you like your 17x8 ?
im thinking of going to 17x8 rim and appropriate tire -- not asking specifically about how you like your tires on 8" wide - but overall how did it change your driving / handling / daily driving / suspension...
im still thinking just doing 17x7.5 and keep it as close to the original stock setup as possible but jsut asking how you guys like your x8 +45/48 setups....
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 10-22-2012, 02:48 AM   #2
HSC
Drives: Whiteout FR-S
I like my 17x8 +48 w/ 235/45/17. They track a lot better and you definitely feel more planted over stock. One thing I didn't expect w/the setup is the drop in fuel economy...my guess is about 4-5mpg. I've only put a few hundred miles on this setup so hopefully that improves but I'm pleased with it overall.
HSC is offline   Reply With Quote
Old 10-22-2012, 03:54 AM   #3
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Did you account for the speedo inaccuracy due to the larger diameter tires?
Your actual mpg should not really be much different. The mpg based on the speedo data will appear lower than reality.
235/40 is a bit closer to stock diameter.
245/40 is almost exactly stock diameter (but better suited for a 9" rim)
uspspro is offline   Reply With Quote
Old 10-22-2012, 05:52 PM   #4
HSC
Yeah, even if i factor in the ~3% difference in diameter, i still come up short on the gas mileage. The mileage isn't bad but it isn't what it use to be. Oh well...
Old 10-22-2012, 07:51 PM   #5
brz7400
brz7400's Avatar
Drives: Subaru BRZ
maybe you are gassing it out of corners harder, now that there is traction
brz7400 is offline   Reply With Quote
Old 10-24-2012, 10:26 AM   #6
Monster
Drives: gc8
hmm I bet some RS3's or RA-1s would make it feel 100% better haha
Monster is offline   Reply With Quote
Old 10-24-2012, 11:18 AM   #7
diirk
diirk's Avatar
Drives: 4Runner
Also check your tire pressure. 5 mpg is a really big difference for such a small increase in tire size. Also curious what wheels and tires you're running.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 10-24-2012, 01:32 PM   #8
schtebie
Drives: CBS BRZ Limited
I've only put about 70 miles on my 17x8 +37 wheels, but I'm very happy so far.
I'm also running 225/45/17 Michelin Pilot Super Sports. Very quiet, light, and sticky tire.
schtebie is offline   Reply With Quote
Wheel Directory: XXR 527 17x8.25 +35 MF_DEUCE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-25-2019 06:37 PM
Wheel Directory: WedsSport TC105N 17x8.0 +42 Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 94 06-21-2019 04:33 AM
Pic request...17x8 +35.... fl_speed001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-17-2012 04:07 AM
Wheel Directory: Advan RG II 17x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-11-2012 07:28 PM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
