Old 10-04-2012, 09:03 PM   #1
KamalT
Drives: Pearl 86 GT
FT86 GT manual gear indicator
This is for the FT86 GT manual spec cars that do not have the white cluster dashboard. Not sure if it will work on the Scion FR-S or the GTS models
To show what gear you are in.
1/ Press the Odometer button and your odometer should light up.
2/ Cycle to you see G Off.
3/ Hold the odometer in the G Off mode and it should change to G ON.
4/ end..
So now when are driving it will tell you wish gear you are in.
Pics to follow...
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 10-04-2012, 09:07 PM   #2
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Mine works as well and I have a Canadian model
Bu-Tang is offline   Reply With Quote
Old 10-04-2012, 09:35 PM   #3
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
this is old
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-04-2012, 09:43 PM   #4
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
And it gives you an indication when to upshift to save fuel. Quite annyoing in a sportscar that needs 4700 rpm to wake up. I turned it off after one trip. I know perfectly well which gear I am in because I am operating the stick.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
Manual Downshifting to 1st Gear Kundiethala Scion FR-S / Toyota 86 GT86 General Forum 45 08-31-2013 07:08 PM
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 10:20 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
