Old 08-17-2012, 05:07 PM   #1
Kundiethala
Drives: Scion FRS 6M Whitout
Manual Downshifting to 1st Gear
Im def no expert in driving stick but have practiced the basics on my brothers chevy cruze for the past year. When ever coming to a full stop from like 45 mph, I would hold in the clutch while placing the car into 1st gear in preparation for after the stop. The clutch would be engaged the whole time i was braking and until the light turned green. Never found a problem with the cruze so it became a routine at every stoplight or stopsign.
Just picked up a MT FR-S yest and in the same situation (slowing down for red light from 45) when I have the clutch all the way down, I tried to put it into 1st gear, I hear a grinding sound. Did I just learn it the wrong way on a beater car or is something wrong with my car. After I heard the grinding, I switched to only moving the gear into neutral to slow down. Sorry if this is a really dumb question. This is my first real car and dont wanna mess it up.
Kundiethala is offline   Reply With Quote
Old 08-17-2012, 05:14 PM   #2
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Rev matching. Goose the gas and it will go into gear much easier.
5hairpins is offline   Reply With Quote
Old 08-17-2012, 05:16 PM   #3
Snozzberries
Drives: FR-S Whiteout
The car won't let you drop into first gear until you are below 10 mph or matched for revs (if you are going 20 you would need to rev up to around 5 grand) is what I have been seeing. Ideally you will be downshifting through all your gears as to not wear on your brakes as much. If you do this right you will barely need to break and will have as smooth as a deceleration as if you were braking, figure out heal toeing as well. This is just the habit I was taught.
Snozzberries is offline   Reply With Quote
Old 08-17-2012, 05:17 PM   #4
Turbowned
Turbowned's Avatar
Most manual cars will keep you out of being able to shift into first gear until you're going very slow (<10mph). You can try forcing it but it's not good for the transmission, hence your crunching sound. Keep it in second til you're at a mostly dead stop. Besides, shifting into first when you're still in motion makes for herky jerky driving which passengers don't enjoy.
Old 08-17-2012, 05:19 PM   #5
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Usually most cars I've driven won't allow me to input first gear while applying mild force until the speed of the car comes to around 10-15mph. Now if you push the gear hard enough you may be able to put it in at higher speeds but may cause the grind. Try this while coming to a stop, clutch in and try and go into first gear but without pushing, keep holding it there and you'll see when reaching <15 the tranny will allow you to input it.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-17-2012, 05:23 PM   #6
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Two things -
Leave it in gear when slowing down. You save more gas this way and you can easily accelerate if you need to.
You shouldnt put it into first if youre going faster then ~10mph. Go into second. Hell, at 45mph, thats third gear.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-17-2012, 05:31 PM   #7
FRSowner
Drives: Hot Lava A/T
Brake pads are much cheaper and easier to change than clutches. I recommend using the brakes to slow down. It's easier on the car and much more controllable.
FRSowner is offline   Reply With Quote
Old 08-17-2012, 05:32 PM   #8
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
Downshifting might save your brakes, but it puts more wear and tear on engine. Cheaper to replace brakes as oppose to engine work.
speedy racer is offline   Reply With Quote
Old 08-17-2012, 05:40 PM   #9
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Some wear and tear on the clutch and the flywheel, yes
But downshifting is not at all bad for the engine. It was made to be rev-ed.
With proper driving techniques (downshifting and foot brake), you can save gas (believe it or not) and your brakes. Win-Win
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 08-17-2012, 05:46 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Downshift while slowing down, not to save brakes, but to always be in the right gear should you need to accelerate.
Done properly, no issues as far as engine/trans/clutch wear. Clutch in a modern car will last approximately FOREVER if not abused. I have always downshifted through the gears in my S2000. 149k miles, 22+ track days, original clutch/trans/engine.
Usually not necessary to downshift to 1st, though I do that as well just to keep practiced in heel/toe rev-matching.
Old 08-17-2012, 05:52 PM   #11
empower-auto
Kouki-Monster
empower-auto's Avatar
Street driving you should never have to downshift to first in the traditional downshifting method. You should be going slow enough that 1st is absolutely warranted and then I recommend going from 2nd to neutral, letting the revs drop and slowing down a lot and then engaging 1st from a very slow roll. Treat your car well
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-17-2012, 06:32 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I've never had a car actively prevent me from shifting into first above 10mph. And that includes my BRZ. The thing is, the engine has to rev very high to match the car's speed in first. This disparity means the synchros need to work very hard to get everything up to speed, which they usually can't.
However, with proper double-clutching and rev matching, you can shift into 1st at any speed.
Here's a downshift into 1st at speed, at 0:13
[ame="http://www.youtube.com/watch?v=_Jw2_Krx_1g"]7/1/12 OVR SOLO (BRZ Drift) - YouTube[/ame]
Old 08-17-2012, 07:21 PM   #13
Snozzberries
That was a clean down shift!
Old 08-17-2012, 11:33 PM   #14
winter
winter's Avatar
Drives: Argento FR-S 6MT
Originally Posted by civicdrivr View Post
Two things -
I second these points.
If you leave your car in gear and don't push in the clutch while slowing down your car doesn't burn gas to keep your engine turning.
winter is offline   Reply With Quote
downshifting, first gear, manual, shifting
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 11:40 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
