Old 06-21-2012, 10:24 PM   #1
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
MT gear indicator
Dont know if this new or not, did a search and came up with nothing. This is for MT and it just tells you what gear you are in. I made a little video on how to turn it on and how it looks.
WolfsFang is offline   Reply With Quote
Old 06-21-2012, 10:29 PM   #2
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
http://www.ft86club.com/forums/showt...tor#post256120
But thanks for making another video!
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 06-21-2012, 10:31 PM   #3
WolfsFang
Scrape Master
WolfsFang's Avatar
dammit always to late >:C.
Old 06-21-2012, 10:33 PM   #4
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
So should we watch both and post which we prefer? HaHa
jedibow is offline   Reply With Quote
Old 06-21-2012, 10:34 PM   #5
Linseal
Linseal's Avatar
Drives: Argento MT Scion FR-S
Yesssss! This is awesome! Thanks!
Linseal is offline   Reply With Quote
Old 06-21-2012, 11:13 PM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Yes vote for me!
Old 06-21-2012, 11:16 PM   #7
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
Well since we are talking about it right now, after the breaking in period what would be the sweet spot to set this too.
LeavingNormal is offline   Reply With Quote
Old 06-21-2012, 11:32 PM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
You mean the shift indicator? You can set it to what ever you feel is the best time to shift when you are pinning it. As you can see in the video I have it at 6k rpm, might move it to 6.5k rpm.
Old 06-22-2012, 12:08 AM   #9
Lytheum
Drives: 2013 BRZ Premium 6MT
turned mine on today playing around. i guess its good for those brain fart moments when i forget to put it in first.
also turned on the shift light/beep and set to 4k rpm for the rest of my break in
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 06-22-2012, 12:49 AM   #10
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
It only shows up after engaging the clutch though, so if you leave it in neutral and forget to put it in first, you'd still be revving at the stoplight right? (Happened to me once )
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 06-22-2012, 01:24 AM   #11
LeavingNormal
FRS2DTH
Nice thanks, I had mine set pretty low for the break in period.
Old 06-22-2012, 03:29 AM   #12
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Except for reverse ( which is the only gear that gets indicated whenever you select it - even with the clutch pedal depressed) ... Very useful too.
Vracer111 is offline   Reply With Quote
Old 06-22-2012, 08:13 AM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
Haha happened to me. Im guessing why it takes a sec to show the gear after the clutch is out id because I think the ecu us trying to calculate it.
Sent from my DROID X2 using Tapatalk 2
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
Old 06-22-2012, 08:57 AM   #14
Linseal
Linseal's Avatar
Hey what does the little red triangle that pops up next to the get number mean?
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
H-86-H side indicator. seannyice81 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-10-2012 10:01 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
Gear indicator Slick CANADA 18 05-20-2012 10:14 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
