Old 09-19-2012, 03:40 PM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
keeping the noise generator with turbo!
wondering if anyone tried it yet, is the whistling inside the car bareable or should i take it out when my setup is finished?
Silverdub is offline   Reply With Quote
Old 09-19-2012, 04:09 PM   #2
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
it probably wont whistle. The sound generator vibrates with the intakes resonance like a speaker.
uspspro is offline   Reply With Quote
Old 09-19-2012, 04:24 PM   #3
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
so i should just take it off and block the damn hole
Old 09-19-2012, 04:55 PM   #4
mike2100
mike2100's Avatar
Drives: 23 BRZ
Just don't attach it to the pressure side or you'll probably blow out the diaphragm!
mike2100 is offline   Reply With Quote
Old 09-19-2012, 05:01 PM   #5
Cheddar
Saving them pennies...
The boost pressure will probably blow it right off. Remember there is vac in that system when NA.
Cheddar is offline   Reply With Quote
Old 09-19-2012, 06:21 PM   #6
rusty959
Drives: DGM BRZ limited
Try it and let us know what it does. I doubt anyone has tried it so far. However, definitely don't attach it to the intake side unless you are willing to blow the diaphragm out as stated previously.
This doesn't relate unless it is in fact hooked to the intake side of the turbo, likely blowing the diaphram.
no there isn't, atleast no major vacuum unless your air filter sucks. There is only significant vac between the engine and throttle body.
rusty959 is offline   Reply With Quote
Old 09-19-2012, 09:05 PM   #7
Cheddar
I didn't say there was alot of vac. Just that there was.
Hey maybe at 10psi youll have another AC vent in the car lol
The Following 2 Users Say Thank You to Cheddar For This Useful Post:
ngabdala (09-19-2012), Sportsguy83 (09-24-2012)
Old 09-19-2012, 09:48 PM   #8
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I will obviously hook it up between the turbo and the filter lol
Old 09-20-2012, 01:55 AM   #9
Mitch
form follows function
Drives: RIP '13 BRZ
To quote futurama, as the Planet Express was being dragged down through the depths of the sea and external pressures were building:
"How many atmosphere's can it take!?"
"Well, seeing as it's a spaceship, anywhere between zero and one."
Mitch is offline   Reply With Quote
Old 09-20-2012, 03:48 AM   #10
gmookher
if getting turbo
then get real exhuast
ditch wimpy sound gen gizmo
real throaty exhaust and the car sounds right in and out
Old 09-24-2012, 12:53 AM   #11
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Yeah. That only blows heat when the engines on a load.
Yes the piping will be replaced anyway.
Well you could you the stock piece but.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 09-27-2012, 01:22 AM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
Why on earth would you still want the noise generator? If you're boosted your blow off valve + wastegate will be doing the majority of the noise making. Much cooler noises too.
Sent from my Nexus 7
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
raz0rbladez909 (09-27-2012)
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Noise Generator Delete for $10.00 xcelir8brz Engine, Exhaust, Transmission 85 11-23-2014 01:39 PM
Noise Generator Delete Plug Dimensions neutron256 DIY (Do-It-Yourself) Guides 26 04-01-2013 12:16 AM
Firewall Plug for noise generator Uniquedetail Engine, Exhaust, Transmission 5 09-19-2012 09:16 PM
Keeping The Wheel and Shifter clean LeavingNormal Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 06-23-2012 03:18 AM
