Old 09-10-2012, 04:22 PM   #1
Craig
Craig's Avatar
Drives: Asphalt FRS
Stock ECU
I was looking for a quote on a OEM ECU. I plan on purchasing a tune but it voids the warrantee which comes with the car. In my wonderfully thought out plan I've decided to purchase a stock ECU to drop in my car if I ever need to utilize the warrantee.
Thanks
~Craig
Craig is offline   Reply With Quote
Old 09-10-2012, 04:28 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
ECUTek tuned ECU's can be flashed back to stock if you ever need to take your car in for warranty so why waste money on another ECU?
Old 09-10-2012, 05:55 PM   #3
Craig
Craig's Avatar
Drives: Asphalt FRS
Didn't know that, first time getting into tuning etc ^^.
+1!
Old 09-10-2012, 05:56 PM   #4
Sportsguy83
Drives: Limited BRZ
I know its a LOT to read, but read Vsconti's tune info thread. You will learn a lot about it.
Old 09-10-2012, 06:00 PM   #5
gmookher
cause corporate can tell if its been reflashed
gmookher is offline   Reply With Quote
Old 09-10-2012, 06:06 PM   #6
Sportsguy83
Drives: Limited BRZ
No, corporate cannot tell if it has been flashed with ECUTek AS LONG as you flash back to stock.
Old 09-10-2012, 06:38 PM   #7
gmookher
saw a thread on here so I asked my contact at subaru...my stealerships service manager confirms me they can see a field that shows the 'write count' on the ecu, anything greater than = 1 its been reflashed. he's very pro mod and rallys his sti.
sorry Sportsguy83, I trust him unless you have evidence otherwise
Old 09-10-2012, 06:48 PM   #8
Craig
Craig's Avatar
Drives: Asphalt FRS
So the consensus here is dealerships can tell if the ECU has been reflashed, meaning purchasing a stock ECU in case there is a need for warrantee claim is a good idea?
Old 09-10-2012, 07:33 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
http://www.ft86club.com/forums/showp...0&postcount=27
Old 09-10-2012, 08:19 PM   #10
Visconti
Drives: 05 STi
^ this explains it perfectly.
Your service guy might know some things but I've personally have used this tool and know how it works. I've also used it side by side a service rep while Subaru north America was checking ecu status before accepting a large warranty claim.
The tools can put a flash count on the ecu just like the ecutek tool can. That flash count is only good for the dealer tool just like the ecutek flash count is only good for the ecutek tool. They can't see each others flash count. The dealer tool only puts a flash count in the ecu when a recall is in place that calls for a flash update. That's the only time. Subaru north America can have the dealer pull up a screen that will tell them if the ecu data is NOT stock. Dealer doesn't know what the data is or means as its only a string of what looks like random numbers - but it's not random numbers
John
Visconti is offline   Reply With Quote
Old 09-11-2012, 06:39 AM   #11
Sportsguy83
Drives: Limited BRZ
sorry gmookher, as you can read Visconti has found otherwise and that was my proof.
Old 09-11-2012, 07:06 AM   #12
gmookher
sounds like they can tell
Old 09-11-2012, 07:36 AM   #13
Sportsguy83
Drives: Limited BRZ
I hope you did read my previous post. Look at the Bold part...
Old 09-11-2012, 08:31 AM   #14
Visconti
Drives: 05 STi
They only check this kind of stuff for warranty work on a blown motor lol
These guys aren't the warranty police, they want you in and out - that's how they make money
Stock FR-S/BRZ shock dyno & stock FR-S spring dyno xwd Tracking / Autocross / HPDE / Drifting 16 08-07-2014 09:04 PM
Stock FR-S amp sirhc Electronics | Audio | NAV | Infotainment 36 01-18-2014 08:38 AM
BRZ stock in BC delsol97 CANADA 8 07-05-2012 09:39 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
Stock or JZ? Samdajiggaman Engine, Exhaust, Transmission 62 05-25-2011 06:12 PM
