Drives: 92 lexus sc300 > whiteout MT FRS
Reverse light not working
Hey my reverse light was intermittent, I had to jiggle my manual gear shifter and it would work sometimes and now I don’t get anything. Do anyone else have a problem with their reverse light and what was the fix? Where is the reverse light switch located? Is it under the hood somewhere? Thanks!
#2 | |
![]() I'd suggest you check the bulb(s) and then check the fuse. I'd guess the switch is somewhere around the transmission - ![]() Check here: - Compliments of @Ultramaroon https://gt86stuff.onrender.com/t3Por..._rm_index.html |
Famous Potatoes
Drives: '15 ultramarine
Mine is out. It was the switch. I bought one but haven't swapped it out yet. The connector for the switch is right on top about where the engine and granny bolt together. Then it runs down and the switch is on the side of the tranny. You can unplug the switch under the hood and make a little jumper out of an inch piece of wire and plug it in instead of the switch. If the reverse lights come on, it's the switch.
Famous Potatoes
Here is the connector. You can follow the wire with a flashlight under the hood and see the switch on the side of the tranny.
not playing cards
My reverse light is out too. It's in a box.
Famous Potatoes
My reverse light question is, can you change the switch without dropping the tranny?
Famous Potatoes
not playing cards
#10 |
Speaking of reversing stories - have I told this one?
When I was about 10 years old I was backing up our steel wheeled tractor to hitch up to a disk. My grandfather was between the tractor and disk, holding up the tongue of the disk so as it could get coupled. I was leaning waaay back to see the hitch when my foot SLIPPED OFF of the clutch pedal. My grandfather's leg was trapped between the steel wheel of the tractor and the 10 foot disk - ![]() After I pulled up, he yelled for me to run up the farm house and get my mom to take him to the doctor! Yep, my history of bad backing up goes waaaay back -
#11 |
not playing cards
Oof... That's a rough memory. I'm sorry. Hope your grandfather wasn't too badly injured. Valuable lesson learned. Well, hmmm... maybe not so much.
#12 |
Drives: Crapcan
There is plenty of room. May have to route the wire by braile following the neutral switch wire
#13 |
#14 |
Drives: Crapcan
I won’t be home till late Friday night but I’ll take pictures Saturday morning. Basically disconnect reverse light switch connector on top of the bell housing. Then jack up the passenger side of the car. You should be able to feel around and get the wire and connector for the reverse light switch out. Then unthread the switch. It’s in the passenger side on the tail housing towards the top. Should be enough room.
| Tail lights not working, brake lights and turn signals are working | Inter | Electronics | Audio | NAV | Infotainment | 10 | 09-15-2022 01:50 AM |
| Tail light, fog light, license plate light not working | FR-Sky | Issues | Warranty | Recalls / TSB | 9 | 07-09-2018 12:01 PM |
| Reverse lights not working after Short Shifter install | SDIAZ | Issues | Warranty | Recalls / TSB | 0 | 01-15-2014 11:12 PM |
| NEED HELP!! Reverse Lights Are Not Working! | GarageBRZTuning | Issues | Warranty | Recalls / TSB | 2 | 11-27-2013 11:13 PM |
| help! reverse light not working | nab335 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-14-2013 05:59 PM |
