Old 03-26-2025, 06:25 PM   #1
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
Reverse light not working
Hey my reverse light was intermittent, I had to jiggle my manual gear shifter and it would work sometimes and now I don’t get anything. Do anyone else have a problem with their reverse light and what was the fix? Where is the reverse light switch located? Is it under the hood somewhere? Thanks!
speedy racer is offline   Reply With Quote
Old 03-26-2025, 07:14 PM   #2
Not much help here -
I'd suggest you check the bulb(s) and then check the fuse.
I'd guess the switch is somewhere around the transmission -
Check here: - Compliments of @Ultramaroon
https://gt86stuff.onrender.com/t3Por..._rm_index.html
Old 03-26-2025, 07:45 PM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Mine is out. It was the switch. I bought one but haven't swapped it out yet. The connector for the switch is right on top about where the engine and granny bolt together. Then it runs down and the switch is on the side of the tranny. You can unplug the switch under the hood and make a little jumper out of an inch piece of wire and plug it in instead of the switch. If the reverse lights come on, it's the switch.
Old 03-26-2025, 08:04 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Here is the connector. You can follow the wire with a flashlight under the hood and see the switch on the side of the tranny.
Old 03-31-2025, 09:16 PM   #5
My reverse light is out too. It's in a box.
Old 03-31-2025, 09:25 PM   #6
Do cars have reverse lights?
Old 04-01-2025, 11:11 AM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
My reverse light question is, can you change the switch without dropping the tranny?
Old 04-01-2025, 04:07 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
And rear view mirrors!
Old 04-03-2025, 02:14 AM   #9
I've heard stories
Old 04-03-2025, 12:13 PM   #10
I've heard stories
Speaking of reversing stories - have I told this one?
When I was about 10 years old I was backing up our steel wheeled tractor to hitch up to a disk. My grandfather was between the tractor and disk, holding up the tongue of the disk so as it could get coupled.
I was leaning waaay back to see the hitch when my foot SLIPPED OFF of the clutch pedal. My grandfather's leg was trapped between the steel wheel of the tractor and the 10 foot disk -
After I pulled up, he yelled for me to run up the farm house and get my mom to take him to the doctor!
Yep, my history of bad backing up goes waaaay back -
Old 04-06-2025, 01:47 PM   #11
Oof... That's a rough memory. I'm sorry. Hope your grandfather wasn't too badly injured. Valuable lesson learned. Well, hmmm... maybe not so much.
Old 04-06-2025, 02:50 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is plenty of room. May have to route the wire by braile following the neutral switch wire
Old 04-24-2025, 04:48 PM   #13
speedy racer
How do you reach the switch without dropping the transmission?
Old 04-25-2025, 12:58 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I won’t be home till late Friday night but I’ll take pictures Saturday morning. Basically disconnect reverse light switch connector on top of the bell housing. Then jack up the passenger side of the car. You should be able to feel around and get the wire and connector for the reverse light switch out. Then unthread the switch. It’s in the passenger side on the tail housing towards the top. Should be enough room.
Tail lights not working, brake lights and turn signals are working Inter Electronics | Audio | NAV | Infotainment 10 09-15-2022 01:50 AM
Tail light, fog light, license plate light not working FR-Sky Issues | Warranty | Recalls / TSB 9 07-09-2018 12:01 PM
Reverse lights not working after Short Shifter install SDIAZ Issues | Warranty | Recalls / TSB 0 01-15-2014 11:12 PM
NEED HELP!! Reverse Lights Are Not Working! GarageBRZTuning Issues | Warranty | Recalls / TSB 2 11-27-2013 11:13 PM
help! reverse light not working nab335 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-14-2013 05:59 PM
