Old 10-28-2012, 10:11 PM   #1
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
Question help! reverse light not working
hey guys,
i installed leds the other day in my reverse lights and for some reason the left one did not work. i replaced the led with the stock bulb and it still wasnt working so I'm guessing I either broke something or maybe unplugged a wire?Any ideas? Your guys helps greatly appreciated
IG: nabb335
nab335 is offline   Reply With Quote
Old 10-28-2012, 10:25 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Check the fuse for the backup lights located in the driver's side footwell area.
cnk is offline   Reply With Quote
Old 10-28-2012, 10:28 PM   #3
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
Originally Posted by nab335 View Post
hey guys,
Is it possible that the led was reversed and the old bulb got damaged?
You could try another bulb. If that doesn't work check the wiring to the socket to see if it's loose.
Worse case, reinstall the OEM bulbs and take the car the dealer.
kwood9000 is offline   Reply With Quote
Old 10-28-2012, 10:49 PM   #4
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
did you try flipping the LEDs, when i installed mine they didnt work initially, i had to remove them from the plug flip them and put em back in.
briang0901 is offline   Reply With Quote
Old 10-14-2013, 05:59 PM   #5
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
i have the same problem, my LED bulbs were installed and operational, but few months later i installed the backup camera, it stopped working, fuses are okay, and i did not touch the OEM wiring in the back of the car, only the front where the adaptor was installed, which i was told by the manufacturer beat-sonic that it is not related to that.
any updates on how you solved this?
Zardoman is offline   Reply With Quote
Third brake light not working....what should i do before bringing it in? Hotlava86 Issues | Warranty | Recalls / TSB 11 03-10-2016 12:12 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
