Drives: 2013 Scion FRS
Hey guys, hope you've been well. Car just made 100K miles. My plugs finally shit the bed a month or two ago, so I replaced all of them and all of my ignition coils with OEM parts.
Last week I got cylinder 3 misfire. Like...completely dead. Had to tow the car. Swapped the coil into cylinder 1 to see if it was the plug or the coil - lo and behold, cylinder 1 started misfiring. So I figured, shitty coil, replaced it. Problem resolved, no biggy. Now today, after a couple of boosts (Sprintex 210) I'm getting a cylinder 1 misfire. It only seems to happen at idle and low load. I have a replacement coil and plug - but I would really like to solve the root of the issue. Everything looks fine on my OSDB reader. Also I'll mention that my car hasn't pulled any timing, so I don't believe the issue to be knock-related. Anybody have any ideas? Thanks in advance.
ScreamingElectron - SnakeShit |
#2 | |
![]() ![]() Sent from my Pixel 7 using Tapatalk
Drives: 2013 frs base
What brand of plugs do you have. I don't recall seeing the electrode that recessed in standard oem plugs.
not playing cards
lol spark plug modz
Anti stance.
2 threads in 2 days for the exact same thing with the exact same post?
Drives: brz 2017 hksv2
and have you ever looked at logs while driving it hard or you have no clue if it s detonating ?
Just DENSO oem plugs that keep failing. 2 posts on 2 threads because I didn't get a response in over a day on this one.
Yes, I have logged my pulls, am not knocking or pulling timing. Sent from my Pixel 7 using Tapatalk
#8 | |
Drives: 22 BRZ limited
If it didn't start that way, then you have some detonation or something wrong going on inside that cylinder.
#10 |
Anti stance.
Is the knock sensor muted in your tune?
#11 |
how much PI% do you have at high rpm high load?
how far is the end of injection to the spark ignition? there is a value for that in ecutek measured in milliseconds do you have access to an external wideband afr sensor ? |
#12 | ||
not playing cards
#13 |
kek
#14 |
I'm chalking it up to chinese plugs. No knock, nothing about the tune or timing or fueling or scaling has changed since I swapped the plugs. Seems to run fine now.
| Tags |
| boost, coil pack, ignition, misfire |
| Misfire on cylinder 1 | MrScrublord | Issues | Warranty | Recalls / TSB | 7 | 01-30-2023 08:30 AM |
| Single Cylinder Misfire | B T | Engine, Exhaust, Transmission | 4 | 09-30-2021 02:01 PM |
| Logs - Misfire Cylinder #1 | Butterballz | Issues | Warranty | Recalls / TSB | 8 | 06-06-2021 11:47 AM |
| HELP P0354 Cylinder 4 Misfire | isaiah990 | Issues | Warranty | Recalls / TSB | 17 | 12-28-2019 10:38 PM |
