Old 09-29-2021, 05:18 PM   #1
B T
Single Cylinder Misfire
Hey guys, I have a single cylinder misfire that's been going on ever since I built my engine. Really don't want to tear it back apart as I'm in an apartment right now. Only happens on Cylinder #1, hot/cold doesn't matter. I've tried swapping/replacing plugs and coils but it always stays on the same cylinder. Any ideas on other things to test?
B T is offline   Reply With Quote
Old 09-29-2021, 06:48 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Injectors
Compression on all four. Is #1 lower than the others?
Old 09-30-2021, 09:05 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Is the engine actually missing or are just getting P0301 or both?
Old 09-30-2021, 09:24 AM   #4
B T
It doesn't sound like it's missing to me, but its throwing the P0301 code, so my tuner backed out of timing.
Old 09-30-2021, 02:01 PM   #5
FrickingReallySlow
Drives: 2015 FR-S
Also SC'ed and I occasionally get a misfire on cyl#1 but I would only see it if I do a ecutek log, don't hear anything or see any engine codes. Tried logging lots of parameters but nothing really coincides with it. My DT tune never uses any port injection only DI and always wondered if that's a problem.
How often do you get it? like once in a 30min drive?
FrickingReallySlow is offline   Reply With Quote
Cylinder 1 Misfire Under Throttle Butterballz Issues | Warranty | Recalls / TSB 26 09-12-2022 12:03 PM
Logs - Misfire Cylinder #1 Butterballz Issues | Warranty | Recalls / TSB 8 06-06-2021 11:47 AM
P0300 Random cylinder misfire Grady Issues | Warranty | Recalls / TSB 6 12-02-2020 11:52 AM
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 10:38 PM
