Old 06-02-2021, 01:30 PM   #1
Butterballz
Drives: Black FRS
Logs - Misfire Cylinder #1
Hi,
So I've been logging my tune and was wondering how much misfire is normal if any? I've been logging the misfires in all cylinders and during a 15 minute light drive, it looks like cylinder 1 misfired 572 times total while the other 3 have zero misfires. Zero misfire codes so just making sure if this is normal or I need to bring it up with tuner. New spark plugs and coil packs as well.
Thanks!
Butterballz is offline   Reply With Quote
Old 06-02-2021, 02:12 PM   #2
Zero is ideal. A few is OK. 572 times in 15 minutes is asking to throw a rod through the block!
Old 06-02-2021, 03:18 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Anything else you have recently done to the car?
Old 06-02-2021, 03:51 PM   #4
Butterballz
Drives: Black FRS
Installed a flex fuel kit, new oem spark plugs, and ignition projects coil packs. Talked to my tuner and he said said a count that large should have a P0301 code as well but no CEL or code. Tuner's response tells me this isn't optimal.
I'll try swapping the coil packs arounds to see if that's the issue.
Old 06-02-2021, 05:17 PM   #5
Grady
Grady's Avatar
“Isn’t optimal”
Get that shit fixed!
Old 06-02-2021, 05:26 PM   #6
Butterballz
Drives: Black FRS
Took a closer look at both logs. One is idling for 15 minutes and the other is light cruise for 15 minutes.
One log has misfire #1, no misfires in the other three. The other log has misfire #2 & #4, no misfire in the other two. Strange, guess I’ll be troubleshooting all weekend.
Old 06-02-2021, 06:42 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check the DI driver module. Make sure all mounting bolts are present and properly tight. It is on the passenger side on top of the head. You likely had to move it if you did plugs. It grounds through its mounting bolts and will cause issues if not tight.
Old 06-03-2021, 12:45 PM   #8
Butterballz
Drives: Black FRS
LOL NVM I think I was reading the logs wrong. I'm using Ecutek to read the misfire and none of the individual values is greater than 1. Tuner said it should be a value between 0-100 so I'm assuming it detected 1 over X amount of seconds, not multiple misfires over the X amount of seconds. I'm guessing it adds up so the number should go up if it misfires over a certain amount of time. I just added up the column.
Let me know if I'm wrong.
Old 06-06-2021, 11:47 AM   #9
DarkSunrise
DarkSunrise's Avatar
As a reference point, I logged for misfires on my OFT on my canyon drive yesterday. Total driving time was 3.5 hrs. The canyon portion was entirely 4500-7500 rpm. Also some highway cruising in the 3000-3600 rpm band. No
misfires on cylinders 1-4. This was with E85 tune with OEM plugs (13k miles) and Delicious red coilpacks (2000 miles).
2022 BRZ Build
2013 FR-S Build
P0300 Random cylinder misfire Grady Issues | Warranty | Recalls / TSB 6 12-02-2020 11:52 AM
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 10:38 PM
P0463, u0122, and P0301 Cylinder 1 misfire Shark_Bait88 Issues | Warranty | Recalls / TSB 0 08-12-2019 06:34 PM
Help with OFT Logs FirestormFlex Software Tuning 2 12-08-2015 08:35 AM
