Old 06-02-2024, 02:56 PM   #1
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Exclamation 2nd Cylinder 1 Misfire in 2 weeks
Hey guys, hope you've been well. Car just made 100K miles. My plugs finally shit the bed a month or two ago, so I replaced all of them and all of my ignition coils with OEM parts.
Last week I got cylinder 3 misfire. Like...completely dead. Had to tow the car. Swapped the coil into cylinder 1 to see if it was the plug or the coil - lo and behold, cylinder 1 started misfiring. So I figured, shitty coil, replaced it. Problem resolved, no biggy.
Now today, after a couple of boosts (Sprintex 210) I'm getting a cylinder 1 misfire. It only seems to happen at idle and low load. I have a replacement coil and plug - but I would really like to solve the root of the issue. Everything looks fine on my OSDB reader. Also I'll mention that my car hasn't pulled any timing, so I don't believe the issue to be knock-related.
Anybody have any ideas? Thanks in advance.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 06-04-2024, 05:42 PM   #2
riboyster
riboyster's Avatar
Spark plug keeps gapping itself. Any ideas?
Sent from my Pixel 7 using Tapatalk
Old 06-04-2024, 09:55 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What brand of plugs do you have. I don't recall seeing the electrode that recessed in standard oem plugs.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Opie (06-06-2024), whataboutbob (06-05-2024)
Old 06-05-2024, 02:42 AM   #4
lol spark plug modz
DarkPira7e (06-05-2024)
Old 06-05-2024, 11:00 AM   #5
Tokay444
2 threads in 2 days for the exact same thing with the exact same post?
Old 06-05-2024, 08:35 PM   #6
tomm.brz
Drives: brz 2017 hksv2
and have you ever looked at logs while driving it hard or you have no clue if it s detonating ?
Old 06-06-2024, 04:23 AM   #7
riboyster
riboyster's Avatar
Just DENSO oem plugs that keep failing. 2 posts on 2 threads because I didn't get a response in over a day on this one.
Yes, I have logged my pulls, am not knocking or pulling timing.
Old 06-06-2024, 04:24 AM   #8
riboyster
riboyster's Avatar
It didn't start this way. It ended this way.
The Following User Says Thank You to riboyster For This Useful Post:
blsfrs (06-07-2024)
Old 06-06-2024, 07:49 AM   #9
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
If it didn't start that way, then you have some detonation or something wrong going on inside that cylinder.
The Following User Says Thank You to dragoontwo For This Useful Post:
Opie (06-06-2024)
Old 06-06-2024, 10:25 AM   #10
Tokay444
Is the knock sensor muted in your tune?
Old 06-06-2024, 07:30 PM   #11
tomm.brz
how much PI% do you have at high rpm high load?
how far is the end of injection to the spark ignition? there is a value for that in ecutek measured in milliseconds
do you have access to an external wideband afr sensor ?
Old 06-06-2024, 11:35 PM   #12
tires look wideband af
Old 06-07-2024, 04:40 AM   #13
tomm.brz
kek
Old 06-13-2024, 08:11 PM   #14
riboyster
riboyster's Avatar
I'm chalking it up to chinese plugs. No knock, nothing about the tune or timing or fueling or scaling has changed since I swapped the plugs. Seems to run fine now.
boost, coil pack, ignition, misfire
Misfire on cylinder 1 MrScrublord Issues | Warranty | Recalls / TSB 7 01-30-2023 09:30 AM
Single Cylinder Misfire B T Engine, Exhaust, Transmission 4 09-30-2021 03:01 PM
Logs - Misfire Cylinder #1 Butterballz Issues | Warranty | Recalls / TSB 8 06-06-2021 12:47 PM
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 11:38 PM
