Old 05-07-2024, 05:14 PM   #1
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Questions about replacing Water Pump please
Hi guys, I'm at 111K on my 2013 10 Series and am strict about preventative maintenance. No issues with the car whatsoever but I'm doing some upgrades and maintenance soon and would like to do the water pump. The pump already has an o-ring style gasket on it. Do I still need to use high temp sealant on top of that? Some people say yes, some say no. Preferably am hoping to get feedback from members who have replaced water pump.
Thanks,
Nickel
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 05-07-2024, 05:20 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Thanks,
Nickel
If it's not broken, don't fix it!!!!!!!
DarkPira7e (05-09-2024), humfrz (05-07-2024)
Old 05-07-2024, 06:50 PM   #3
Nickel
Nick
Typical response. I like to prevent things from breaking, not fix things that are broken.
The Following User Says Thank You to Nickel For This Useful Post:
humfrz (05-07-2024)
Old 05-07-2024, 09:02 PM   #4
humfrz
Although ol @Sapphireho 's reply may seem a bit short, in this case he is right on.
I can appreciate your preventative maintenance desires, but sometimes we can get a bit "over preventative" -
I remember waaay back in the day, my first car was a 1948 Chevrolet. I would visit the local junk yard and stock up on spare parts and carry them in the trunk, just in case of a breakdown on the road. Yep, things like an extra fuel pump, spark plugs, ignition points, ignition coil, carburetor, fan belt, plus a generous supply of duck tape and baling wire.
NONE of those things ever went bad while on the road - it was always something else.
Although your car has over 100,000 miles, a faulty water pump doesn't seem like a common problem with these cars.
Therefore, I wouldn't worry about replacing the water pump.
Nickel (05-07-2024), Wally86 (05-09-2024)
Old 05-07-2024, 09:52 PM   #5
Nickel
Nick
I've owned 5 NA Miatas and I'm so used to needing to replace those with the timing belt. I know this isn't that, but I figured since it was so accessible, why not? Is there nowhere in the manual stating this as like 100k service item or anything? I'm surprised if it's not honestly.
humfrz (05-07-2024)
Old 05-07-2024, 11:40 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I haven't heard of the water pump being a weak link in the system so far.
It's usually leaky timing chain covers, main bearings or hopping rockers.
You can take off the belt and check for a wonky bearing though.
My 84 Civic S munched the valve train because the water pump froze up.
It was driven by the timing belt, so, yeah. That was sometime in the early 90's though.
I was five miles from home after driving it to S Cal. and back on a two week vacation.
It was a good car none the less. Kept it til '95 and traded it in on a Grand Caravan.
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (05-07-2024), Nickel (05-09-2024)
Old 05-07-2024, 11:47 PM   #7
humfrz
WOW! You have owned a bunch of interesting vehicles -
I don't see anything in my FR-S manual about the replacing the water pump.
I asked my buddy Bubba and he says that iffen it ain't leaken enough to leave a puddle of the floor, don't worry bout it. He referred me to this:
https://www.yourmechanic.com/article...ing-water-pump
Hells bells, the Model T Ford didn't even have a water pump and the water cooled the engine just fine.
Where was I? ..........
Nickel (05-09-2024)
Old 05-07-2024, 11:55 PM   #8
humfrz
I got the picture -
bcj (05-08-2024)
Old 05-09-2024, 07:04 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Water pump is not a preventive maintenance item. We talk about this once in a while.
https://www.ft86club.com/forums/showthread.php?t=136391
humfrz (05-09-2024)
Old 05-09-2024, 08:48 AM   #10
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
If you start replacing part because they "might" go bad, where do you stop?
Any moving part on the car might go bad at any time but most things like the water pump, pulleys, etc will last 100,000's of miles with out failing. (IMHO)
The Following User Says Thank You to blsfrs For This Useful Post:
humfrz (05-09-2024)
Old 05-09-2024, 10:05 AM   #11
Tokay444
I tried that with a clutch, and got 35,000km out of the new one which was faulty and shat a spring out of the disk which got sandwiched between the disk and flywheel, thankfully, and not the other way.
The Following User Says Thank You to Tokay444 For This Useful Post:
blsfrs (05-09-2024)
Old 05-09-2024, 10:14 AM   #12
Tokay444
See.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post:
bcj (05-10-2024), blsfrs (05-09-2024), Joon525 (07-26-2024)
Old 05-09-2024, 10:56 PM   #13
humfrz
Originally Posted by Tokay444 View Post
See.
Tokay444 (05-10-2024)
Electric water pump TorontoB Engine, Exhaust, Transmission 18 05-18-2021 11:09 PM
Water pump replacement Timmygt Engine, Exhaust, Transmission 18 12-17-2019 07:34 PM
Water Pump Replacement Djratrap Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 01-18-2018 11:29 PM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 05:59 PM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 07:57 AM
