Nick
Drives: 2013 10 Series GT86 #182 of 2500
Questions about replacing Water Pump please
Hi guys, I'm at 111K on my 2013 10 Series and am strict about preventative maintenance. No issues with the car whatsoever but I'm doing some upgrades and maintenance soon and would like to do the water pump. The pump already has an o-ring style gasket on it. Do I still need to use high temp sealant on top of that? Some people say yes, some say no. Preferably am hoping to get feedback from members who have replaced water pump.
Thanks, Nickel
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion |
#2 | |
Famous Potatoes
Drives: '15 ultramarine
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | DarkPira7e (05-09-2024), humfrz (05-07-2024) |
#3 |
Nick
Typical response. I like to prevent things from breaking, not fix things that are broken.
| The Following User Says Thank You to Nickel For This Useful Post: | humfrz (05-07-2024) |
#4 | |
I can appreciate your preventative maintenance desires, but sometimes we can get a bit "over preventative" - ![]() I remember waaay back in the day, my first car was a 1948 Chevrolet. I would visit the local junk yard and stock up on spare parts and carry them in the trunk, just in case of a breakdown on the road. Yep, things like an extra fuel pump, spark plugs, ignition points, ignition coil, carburetor, fan belt, plus a generous supply of duck tape and baling wire. NONE of those things ever went bad while on the road - it was always something else. Although your car has over 100,000 miles, a faulty water pump doesn't seem like a common problem with these cars. Therefore, I wouldn't worry about replacing the water pump.
#5 | |
Nick
I've owned 5 NA Miatas and I'm so used to needing to replace those with the timing belt. I know this isn't that, but I figured since it was so accessible, why not? Is there nowhere in the manual stating this as like 100k service item or anything? I'm surprised if it's not honestly.
#6 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I haven't heard of the water pump being a weak link in the system so far.
It's usually leaky timing chain covers, main bearings or hopping rockers. You can take off the belt and check for a wonky bearing though. My 84 Civic S munched the valve train because the water pump froze up. It was driven by the timing belt, so, yeah. That was sometime in the early 90's though. I was five miles from home after driving it to S Cal. and back on a two week vacation. It was a good car none the less. Kept it til '95 and traded it in on a Grand Caravan.
"I gotta rock." -- Charley Brown |
#7 | |
![]() I don't see anything in my FR-S manual about the replacing the water pump. I asked my buddy Bubba and he says that iffen it ain't leaken enough to leave a puddle of the floor, don't worry bout it. He referred me to this: https://www.yourmechanic.com/article...ing-water-pump Hells bells, the Model T Ford didn't even have a water pump and the water cooled the engine just fine. Where was I? ..........
| The Following User Says Thank You to humfrz For This Useful Post: | Nickel (05-09-2024) |
#8 | |
| The Following User Says Thank You to humfrz For This Useful Post: | bcj (05-08-2024) |
#9 |
Famous Potatoes
Water pump is not a preventive maintenance item. We talk about this once in a while.
https://www.ft86club.com/forums/showthread.php?t=136391 |
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (05-09-2024) |
#10 | |
Drives: 2013 frs base
Any moving part on the car might go bad at any time but most things like the water pump, pulleys, etc will last 100,000's of miles with out failing. (IMHO) |
| The Following User Says Thank You to blsfrs For This Useful Post: | humfrz (05-09-2024) |
#11 |
I tried that with a clutch, and got 35,000km out of the new one which was faulty and shat a spring out of the disk which got sandwiched between the disk and flywheel, thankfully, and not the other way.
| The Following User Says Thank You to Tokay444 For This Useful Post: | blsfrs (05-09-2024) |
#12 |
See.
| Electric water pump | TorontoB | Engine, Exhaust, Transmission | 18 | 05-18-2021 11:09 PM |
| Water pump replacement | Timmygt | Engine, Exhaust, Transmission | 18 | 12-17-2019 07:34 PM |
| Water Pump Replacement | Djratrap | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 01-18-2018 11:29 PM |
| Leaking water pump | DJCarbine | Issues | Warranty | Recalls / TSB | 11 | 05-13-2014 05:59 PM |
| Water pump | Micene | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 03-08-2013 07:57 AM |
