Old 01-18-2018, 09:24 PM   #1
Djratrap
Drives: BRZ CSB Limited
Water Pump Replacement
I'm starting to reach pretty high mileage 130k miles. i usually swap out my water pump/belts on most of my vehicles around this time as preventative maintenance. Has anyone done this yet? Difficulty level?
Djratrap is offline   Reply With Quote
Old 01-18-2018, 10:35 PM   #2
Teseo
Drives: frs
Did you swap the belt? Inspect visually and grab the pulley if have play and turn it over if make any squealing noise or resiatance. Also check for leaks
Old 01-18-2018, 10:43 PM   #3
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have pulled my water pump, just to check it. It's a pretty easy job. You have to remove the pulley 1st, then the water pump. And it will need a new o-ring. It's a pretty sturdy part. I wouldn't worry about it unless it's leaking.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
Djratrap (01-19-2018)
Old 01-19-2018, 12:29 AM   #4
Djratrap
Thanks for the heads up guys. I'm prob going to swap all that out in the spring. Everything is in working order for the time being(belts still look very good).
OEM Water Pump Belt Cover Philly758 Want-To-Buy Requests 2 07-07-2015 07:08 PM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 06:59 PM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 08:57 AM
Water pump reliability - track use Kamran Tracking / Autocross / HPDE / Drifting 13 01-20-2013 11:30 AM
