Old 05-05-2021, 05:33 PM   #1
TorontoB
Drives: Brz
Electric water pump
How much power saving can be saved with electric water pump?
TorontoB is offline   Reply With Quote
The Following User Says Thank You to TorontoB For This Useful Post:
humfrz (05-05-2021)
Old 05-05-2021, 06:04 PM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by TorontoB View Post
How power saving can be saved with electric water pump?
I'm just guessing but I'll say 5hp. Doesn't sound worth the money to me unless you're really determined to get every pony out of the motor with no boost
Old 05-05-2021, 09:48 PM   #3
humfrz
Very little.
Get back in the box! -
scion fr-s (05-05-2021)
Old 05-05-2021, 10:26 PM   #4
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Very little.
Little is better than none.
scion fr-s is offline   Reply With Quote
The Following 2 Users Say Thank You to scion fr-s For This Useful Post:
humfrz (05-05-2021), SuperTom (09-02-2025)
Old 05-05-2021, 10:38 PM   #5
humfrz
Don't encourage him - that's a dumb idea.
Hell, I can remember when water cooled cars didn't have water pumps -
Capt Spaulding (05-06-2021), scion fr-s (05-06-2021)
Old 05-06-2021, 12:18 AM   #6
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I learned “little is better than none” from bubba’s 101 auto class. LOL. It is the same as doing an ac delete. Very minimal weight savings.
The Following User Says Thank You to scion fr-s For This Useful Post:
humfrz (05-06-2021)
Old 05-06-2021, 07:03 AM   #7
Ashikabi
Ashikabi's Avatar
I don't believe that is correct. Your crank directly drives the water pump, which means it uses horsepower to do it. Going electric would free that horsepower. Up to the point that your alternator has to work a little harder that is. You might save a couple pounds but that "hp" change is pretty inconsequential.
Don't get me wrong, plenty of people do it. That's why electric pumps exist. It's just gonna be a really expensive 1.2hp
The Following 4 Users Say Thank You to Ashikabi For This Useful Post:
humfrz (05-06-2021), scion fr-s (05-06-2021), soundman98 (05-06-2021), SuperTom (09-02-2025)
Old 05-06-2021, 07:18 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Electric power also doesn't magically appear. Generator spun by engine saps those HP aswell. Unless of course you charge battery with trickle charger prior every drive and have generator disconnected. Belt or gear driven or electrically driven .. only differences should be in way how energy is taken from crankshaft, directly and proportionally to rpms in former case, or just somwhat averaged over time in later case, as generator and alternator acts more depending on charge of battery, not rpms of engine. Still, to pump X volume of fluid with Y resistance you still spend Z energy .. possibly with less losses in mechanically direct drive. But electric will still need that energy taken from somewhere.
The Following 2 Users Say Thank You to churchx For This Useful Post:
Capt Spaulding (05-06-2021), soundman98 (05-06-2021)
Old 05-06-2021, 08:50 AM   #9
Berserker
I did one on my Stang & probably will do one eventually on my Brz. Like mentioned above it will draw more from the alternator, if anything it's microscopic gains but a big thing is the cooling in the pits. If you remove your thermostat you can have the water pump circulating in the pits while the car is off prepping for the next round or just coming off the track for cool down purposes.
Berserker is offline   Reply With Quote
The Following 2 Users Say Thank You to Berserker For This Useful Post:
Old 05-06-2021, 06:46 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
There could be an advantage to driving it electrically. It would give the ecu the option to reduce the field voltage and reduce the power drawn from the alternator, to reduce the power its taking from the crank, during full throttle. It could continue to power the pump off the battery for brief moments of full throttle. Not really sustainable for racing, but on the street you could gain a solid 3-5hp.
That's entirely not worth it, IMO. But there is sound theory behind the idea.
Sent from my Pixel 4a (5G) using Tapatalk
Old 05-06-2021, 11:47 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Only with extra safeguards in place. Think of what happens if battery is drained almost completely by pump and not charged at normal rate. If you stop engine, you will not be able start back again, once charge is drained .. waterpump may stop working completely. And no battery likes deep discharges, which usually reduce maximum charge it may hold, so soon battery will need to be changed. And if/when (at very late stage) alternator/generator is told to charge back as much as they can emptied battery, "power sap" will be much greater. Now throw in lightweight reduced capacity battery.
Mechanical direct driven pump sounds more fail-safe to me, which seems important bit for track (ab)use.
Old 05-18-2021, 07:51 AM   #12
makinen
makinen's Avatar
Drives: Toyota 86
You do too unsure the tech.
BMW's are already using electric water pumps long time ago.
The electric water pump usually used in our FA20 platform only draws 7.5A max and usually within 50% duty. Even just charging two tablets can take such amperes. If the alternator can't provide those amperes along with charging the battery, the engine can't live with a mechanical water pump too.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 05-18-2021, 08:05 AM   #13
Ashikabi
Ashikabi's Avatar
That and it would be a nightmare to tune that into a computer that was never intended to run an external pump
Old 05-18-2021, 04:34 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm .. IRL it might be less of an issue, as imho many that do that extensive mods may also run aftermarket ECU, such as Motec. Still, main bit i wanted to point out in my post, that no magic energy will be freed by going electric, thus no performance gains are to be expected.
Water pump replacement Timmygt Engine, Exhaust, Transmission 18 12-17-2019 07:34 PM
Electric Water Pumps? Captain Snooze Engine, Exhaust, Transmission 17 01-31-2015 11:45 AM
Electric fuel pump running with car off??? bpracer Issues | Warranty | Recalls / TSB 13 08-08-2013 09:42 AM
Water pump Micene Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-08-2013 07:57 AM
Toning down the electric steering pump possible? kertong BRZ First-Gen (2012+) — General Topics 18 03-03-2013 12:51 PM
