Old 04-27-2024, 11:21 PM   #1
Dazzo
Drives: 2013 FRS
Door Lock Broken/Stuck.
I am currently having this issue with my driver-side door lock and plan to take the door apart tomorrow to investigate, but I was curious if anyone here has had a similar problem before and could potentially speed the process/eliminate some troubleshooting. Sometimes when unlocking the car with my clicker only the passenger side door would unlock leaving the driver side door locked, but the driver side door could be unlocked manually with the key or inside with the switch. Fast forward a few weeks and the driver-side lock switch is completely stuck and unable to be manually opened from the inside without excessive wiggling/force, but even if it is moved to the unlocked position the door remains locked and can only be opened manually from the outside with the actual key. Anyone have a similar issue or potential fixes? A video example is attached.
https://www.youtube.com/shorts/gCLdWiZMZT4
Dazzo is offline   Reply With Quote
The Following User Says Thank You to Dazzo For This Useful Post:
humfrz (05-09-2024)
Old 04-30-2024, 12:41 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
https://www.ft86club.com/forums/showthread.php?t=154678
humfrz (05-09-2024)
Old 05-09-2024, 11:08 PM   #3
humfrz
You might try spraying some silicone spray in and around the latch then let it sit for a few hours - you might get lucky. If not, consider taking off the door panel and spraying everything, even remotely attached to the lock.
I asked Bubba and he says to pound on the latch with the palm of your hand, three times, hard.
Old 06-11-2024, 01:13 PM   #4
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
My driver door won’t open from the inside, I had to take the panel off and reattach the ball on the cable, it did it 2x so don’t pop your door handles too fast.
speedy racer is offline   Reply With Quote
The Following User Says Thank You to speedy racer For This Useful Post:
Ultramaroon (06-11-2024)
Air conditioner is only blowing from defrost/footwell areas (stuck blend door?) Moooiiissst Issues | Warranty | Recalls / TSB 3 02-05-2021 06:16 PM
[Help] Door handle broken (?) URGENT! LeonardoDaVinny Cosmetic Modification (Interior/Exterior/Lighting) 14 03-23-2019 01:30 AM
Reverse lock out button on IRP short shifter is stuck due to my dumb self Mdulin Engine, Exhaust, Transmission 4 01-28-2019 05:44 PM
Shift lock stuck after short Anomie Issues | Warranty | Recalls / TSB 7 01-24-2017 01:44 PM
Driver door check broken jefars Issues | Warranty | Recalls / TSB 8 06-28-2016 09:46 AM
