Old 03-18-2019, 01:05 AM   #1
LeonardoDaVinny
NotVinnyy
Drives: 2013 White Pearl FRS
[Help] Door handle broken (?) URGENT!
So I was taking apart the car for a wrap and removed the driver's door handle. After putting it back together, I noticed that the handle only pulls straight out and has no rebound/tension (does not open the door).
This is the handle from the outside. It just stays pulled out after tugging on it. Has anybody had experience with this and if so, how did you fix it. Thanks!
LeonardoDaVinny is offline   Reply With Quote
Old 03-18-2019, 02:11 AM   #2
humfrz
I reckon there is a spring that pulls the handle back in - that you left out on the rebuild -
I suggest you take apart the other sides handle, see what it has that your busted side does not have - and order one of those.
OR, look around closer on the garage floor - hint, it will be further away than you would think it would be -
OR go to
https://demos.starbase7.net/t3Portal..._rm_index.html
(see the reassemble part for the front door handle)
humfrz
Old 03-18-2019, 03:38 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You done now ducked yourself boy.
Lol aside.....
Two possible problems, you drop the spring, or forgot to fully replace everything.
Time for some YouTube research.
Old 03-18-2019, 03:10 PM   #4
LeonardoDaVinny
NotVinnyy
Lol aside.....
Hmm.. I did not even know there was a spring. I will go look around!
Old 03-18-2019, 03:14 PM   #5
LeonardoDaVinny
NotVinnyy
OR go to
humfrz
I would, but I am afraid of breaking that one as well. It seems like there should be a spring as you stated since the handle fully pulls out, but stops at a certain point with no tension at all. Do you think I should head to the stealership if I cannot find the spring?
Old 03-18-2019, 03:47 PM   #6
ermax
ermax's Avatar
My guess is the linkage detached as you stuffed it back in which is why it isn't being pulled back in and also why it isn't actually opening the door.
Old 03-18-2019, 04:05 PM   #7
humfrz
First, I'd suggest you drill down through the reference I gave you (exterior-front door- latch- reassembly).
Like ol @ermax mentioned, there is a couple of rods that must be inserted/reattached.
humfrz
Old 03-20-2019, 01:49 AM   #8
LeonardoDaVinny
NotVinnyy
humfrz
Looked through it. It seems like everything was attached perfectly on the inside. For some reason, the outside does not seem to latch back on upon reassembly (?)
Old 03-20-2019, 05:37 AM   #9
ermax
ermax's Avatar
Are you saying you took the door back apart and verified that everything is connected?
Old 03-20-2019, 10:59 AM   #10
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
In order to remove the door panel the pull cord for the door handle has to be removed. The hammer end slides up. Remove the door panel and make sure the door latch is correct. Compare to the other side for reference.
Old 03-21-2019, 04:22 PM   #11
LeonardoDaVinny
NotVinnyy
Yes, that is what I did, but it still does not work at all D;
Old 03-21-2019, 04:23 PM   #12
ermax
ermax's Avatar
I've never removed the external portion of the door handle so I don't have any personal experience to share on this unfortunately.
Old 03-22-2019, 08:27 AM   #13
maslin
Benz Tech
Drives: 2017 BRZ Premium
Make sure you’re getting that “hook” on the bottom left behind the latch. Sometimes you have to pull the part in the door out a bit before sliding the handle in. Never had a Toyota/Subaru handle off but they’re all the same. The pic below is an FRS handle.
maslin is offline   Reply With Quote
Old 03-23-2019, 01:08 AM   #14
LeonardoDaVinny
NotVinnyy
Seems like the latch was not able to hook on after repeated attempts. However, the latch is still present, so I am sure it is not broken. I will try to reassemble the handle once again. Hopefully, it works this time while pulling the part in the door!
Broken Trunk Emergency exit handle USMC Scion FR-S / Toyota 86 GT86 General Forum 28 09-05-2022 06:32 PM
FS: Carbon fiber AC cover, black door handle & chrome door lever jorgerendonjr Interior Parts (Incl. Lighting) 3 08-15-2017 01:14 PM
FS : JDM Red Interior Door Handle shadoken Interior Parts (Incl. Lighting) 11 06-02-2017 07:53 AM
Door Handle cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 11 03-24-2013 02:49 AM
For those who have driven into Manhattan, can the FT86 handle broken roads? rogerdalien Scion FR-S / Toyota 86 GT86 General Forum 19 01-02-2013 01:48 PM
