The moisture is real
Drives: '15 WR Blue BRZ Limited 6spd
Air conditioner is only blowing from defrost/footwell areas (stuck blend door?)
Hey guys,
So '15 BRZ's A/C has been acting up lately and since summer is right around the corner, I feel I should address this sooner than later. My AC was working fine since I bought the car new in December of 2014, but now the air only comes out of the front window defrost vents and the bottom footwell vents, no matter how many times I click the middle AC mode button (I have the digital dual climate controls). I could only assume it is the blend door motor that is causing this, but I can't seem to find any guide as to how to get to it to see if that's what it is. Has anyone had any experience with this that could lead me to the right place to look? I've been kicking and smacking my entire dash and footwell panels in hopes to knock the motor loose in case it's stuck. It started working once again randomly without me doing anything abnormal, but only stayed function for about a week and now I can't get it to work again. Any advice to knowing how to get to the blend door motor would be greatly appreciated. Or if anyone has experienced this issue and found a different fix, I would like to hear your ideas as well. Thank you. |
Update: My AC fixed itself again, but I could only assume that it will not stay working forever, so I would still like to take a look at the blend door motor or anything else related to it. Any thoughts?
Take a look through here
https://demos.starbase7.net/t3Portal..._rm_index.html
Drives: 2017 Toyota 86 860 Special Edition
My 2017 86 is doing this but in reverse. My floor heat crapped out, then *magically* started working after a week when I took it in for Diag. I though the same, maybe a blend door freezing up. But now that it works again, it feels like its only mostly working. Before I would sweat my but off at 70 degrees, and would turn defrost and heat on together and it maintained that perfect middle road. Now, the floor heat is only noticeable on higher fan speeds and heat settings. I always use manual settings even for the dual zone. Did you ever find the culprit?
| Underglow/footwell light controlled by door without using dome light or door switch | pcguru2000 | DIY (Do-It-Yourself) Guides | 5 | 06-17-2018 12:09 PM |
| --Autolismo.com, Canada (Pay With CAD$)-- Footwell + Under Door LED Strip | autolismo | Exterior Parts - Lighting | 316 | 11-16-2017 12:24 PM |
| has the door courtesy LED blowing the BIU problem been fixed with 2016 brz? | ed_423 | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 05-11-2016 05:40 PM |
| Footwell Illumination - Door sensor and switch toggle | USN.Spence | DIY (Do-It-Yourself) Guides | 7 | 12-27-2014 02:08 AM |
| Would you like a tutorial for footwell illumination - Door sensor AND switch toggle? | USN.Spence | DIY (Do-It-Yourself) Guides | 6 | 09-11-2014 08:34 PM |
