Old 04-28-2024, 11:13 PM   #1
Dazzo
Drives: 2013 FRS
Door Lock Broken/Stuck.
I am currently having this issue with my driver-side door lock and plan to take the door apart tomorrow to investigate, but I was curious if anyone here has had a similar problem before and could potentially speed the process/eliminate some troubleshooting. Sometimes when unlocking the car with my clicker only the passenger side door would unlock leaving the driver side door locked, but the driver side door could be unlocked manually with the key or inside with the switch. Fast forward a few weeks and the driver-side lock switch is completely stuck and unable to be manually opened from the inside without excessive wiggling/force, but even if it is moved to the unlocked position the door remains locked and can only be opened manually from the outside with the actual key. Anyone have a similar issue or potential fixes? A video example is attached.
https://www.youtube.com/shorts/gCLdWiZMZT4
Dazzo is offline   Reply With Quote
Old 04-29-2024, 02:35 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Issue with the latch itself. Careful with the manual lever. Just plastic parts connected to a cable.
Must be replaced. Most of the cost will be labor. Don't wait.
Door Lock Broken/Stuck. Dazzo Scion FR-S / Toyota 86 GT86 General Forum 3 06-11-2024 01:13 PM
[Help] Door handle broken (?) URGENT! LeonardoDaVinny Cosmetic Modification (Interior/Exterior/Lighting) 14 03-23-2019 01:30 AM
Reverse lock out button on IRP short shifter is stuck due to my dumb self Mdulin Engine, Exhaust, Transmission 4 01-28-2019 05:44 PM
Shift lock stuck after short Anomie Issues | Warranty | Recalls / TSB 7 01-24-2017 01:44 PM
Driver door check broken jefars Issues | Warranty | Recalls / TSB 8 06-28-2016 09:46 AM
