Old 01-04-2024, 06:25 PM   #1
JIM THEO
Drives: BRZ 2018
ProVent air oil separator / catch can anyone?
According to this video
Most of baffled or bronze filter catch cans - Mishimoto included - cause significant crankcase pressure increase which is only bad for the engine.
Has anyone installed Provent 100 or 200 air oil separator to tell us his experience as it causes zero pressure increase and has the best air oil separation?
JIM THEO is offline   Reply With Quote
Old 01-04-2024, 06:56 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
You do not need a catch can or air/oil separator.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
NoHaveMSG (01-04-2024), x808drifter (01-05-2024)
Old 01-04-2024, 10:14 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
...or an oil cooler
NoHaveMSG (01-04-2024), x808drifter (01-05-2024), ZDan (01-05-2024)
Old 01-05-2024, 03:18 AM   #4
JIM THEO
Drives: BRZ 2018
Why you believe we don't need AOS or catch cans, have you ever seen in your intake how much oil/carbon build up is there?
Especially for some of us with remap that use less than OEM map the port injectors, so valves are not cleaned the same!
Old 01-05-2024, 04:01 AM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
My '17 consumed near-enough zero oil between changes at 5k miles and usually 4-6 track days. Like, none. New car similar so far, 15k miles in, essentially zero oil consumption. In the old car, mph at Watkins Glen was the same every year, from new to 78k miles, so I don't think I was losing any power due to oil/carbon buildup or whatever over the years/mileage.
IMO, you dont need an air/oil separator or catch can, but go ahead if you wanna.
Wally86 (01-05-2024), x808drifter (01-05-2024)
Old 01-05-2024, 04:59 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Yes I have.
There is almost none.
Far from the OEM port map/timing on my tune.
Old 01-06-2024, 10:51 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How much intake buildup do you think is normal, even for a purely port injected engine? You will always get some.
Old 01-07-2024, 11:17 AM   #8
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I had a provent 200 on my diesel truck before i sold it but it is way overkill for an NA brz. If you are looking for catch cans I would recommend radium. The only issue they have caused was a fitting was made of some type of plastic and yielded. That was in my wrx and radium sent me a metal fitting to replace it.
Breadman is offline   Reply With Quote
The Following User Says Thank You to Breadman For This Useful Post:
whataboutbob (01-07-2024)
Old 01-07-2024, 06:22 PM   #9
JIM THEO
Drives: BRZ 2018
The less you have the better it's for the engine.
Provent uses elastomers in his catch cans non tested on petrol engines anyway so I ordered a cheap aluminum one!
Old 01-08-2024, 09:14 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are that worried about it then don’t route the PVC back to the intake.
Old 01-08-2024, 09:27 AM   #11
JIM THEO
Drives: BRZ 2018
That's not healthy for the engine I think
Old 01-08-2024, 12:16 PM   #12
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
You'll never feel any difference from adding a catch can (AOS), whether it is "good" or "bad". However, catch cans are for preventative care, in my opinion, to reduce oil fumes being introduced into the intake air, which effectively lowers knock resistance. No car "needs" a catch can. If a catch can is a "solution" to a problem, it is just band aid that will surely result in a negative end.
In addition, for maximum engine efficiency, a vaccum should be pulled on the crank case, especially under high load situations. Depending on engine setup, applying vaccum to crank case can yield over 50 hp, more realistically 1-5 hp (check out some high horsepower Supra's with downpipe venturi ports). This is why it is not a good idea to vent the catch can to the atmosphere, you aren't pulling any vaccum. This is also why it would be a bad idea to add a catch can that is too restrictive, which is what I assume the youtube video is getting at (I didn't watch it).
No experience with Mishimoto, but I highly recommend Chase Bay's catch can. No restriction, baffled, and uses a steel mesh filter.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 01-10-2024, 05:00 AM   #13
JIM THEO
Drives: BRZ 2018
Exactly, and you may have more fumes in the oil
Old 01-10-2024, 07:58 AM   #14
Grady
Grady's Avatar
“Significant pressure increase” does not equal excessive crankcase pressure. All those catch cans do increase crankcase pressure but none created excessive crankcase pressure. I will trade off some more crankcase pressure to reduce blow by in the intake.
oil catch can/air oil separator TOPUTO Engine, Exhaust, Transmission 10 09-22-2017 10:21 AM
Air oil separator vs. catch can snowdog Forced Induction 9 07-25-2015 09:37 AM
Perrin Air Oil Separator/Catch Can! FS Batman Engine, Exhaust, Bolt-Ons 8 03-31-2014 02:02 PM
Air Oil Separator? Do I need one? hmong337 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 12-31-2013 10:14 PM
FS: Cusco Oil Catch Can (Separator Type) howiedoit Engine, Exhaust, Bolt-Ons 4 12-02-2013 12:47 AM
