View Poll Results: Air oil separator vs. Catch can
Air oil separator 6 27.27%
Catch can 10 45.45%
Double catch can 3 13.64%
Nothing 3 13.64%
Voters: 22. You may not vote on this poll
Old 07-21-2015, 02:17 PM   #1
snowdog
Drives: 2013 Scion FRS
Air oil separator vs. catch can
Hey all,
Just wanted to get some idea of what people are running and why?
Air oil separator
Catch can
Double catch can
nothing
snowdog is offline   Reply With Quote
The Following User Says Thank You to snowdog For This Useful Post:
DAEMANO (07-21-2015)
Old 07-21-2015, 03:22 PM   #2
DAEMANO
Time Traveller
PCV Side - Mishimoto Catch can w/ Boomba check valve
CCV Side - Nothing, but a vent-to-air separator or second catch can would probably be a good idea.
Old 07-23-2015, 12:51 PM   #3
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
I guess I don't understand the difference between an AOS and a catch can. Can someone please elaborate?
@DAEMANO, What does that Boomba check valve do exactly? Allow oil to drain back to block?
xkalelx is offline   Reply With Quote
Old 07-23-2015, 01:25 PM   #4
DAEMANO
Time Traveller
I've seen the term "catch-can" and "air/oil seperator"(AOS) used interchangeably. IMO they could semantically be slightly different. A vent-to-air style catch can, doesn't really intend to catch the blow by (that mixture of oil, water, and contaminants) but instead to remove and release it. So this arrangement is more of a true AOS. I could have that totally wrong, but whatever
A check valve helps prevent PCV failures, leaky gaskets, and blown seals caused by excessive pressurization on a boosted vehicle. Since our PCVs were designed for NA and not FI, a check valve is a cheap ($20-30ish) bit of insurance here.
The Following User Says Thank You to DAEMANO For This Useful Post:
xkalelx (07-23-2015)
Old 07-23-2015, 01:58 PM   #5
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
In EXTREMELY short:
Catch can will catch the oil and hold onto it, meaning you'll have to check the contents and empty out occasionally.
Air Oil Seperator will seperate and then return through the engine.
TylerLieberman is offline   Reply With Quote
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post:
erbaker67 (07-23-2015), NyC Zn6 (07-24-2015), xkalelx (07-23-2015)
Old 07-23-2015, 09:01 PM   #6
myioz86
Drives: gt-86 2013
Double catchcans two seperat systems drain it out and through it away dont want this oil,fuel mix going back into your oil supply.
myioz86 is offline   Reply With Quote
Old 07-24-2015, 08:28 AM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
I use a Cusco vehicle specific catch can with stainless steel wool that I stuffed inside. For the 2 weeks I ran at max 9 PSI on my HKS blower it accumulated a tiny bit of oil and I can see no oil inside the throttle body indicating the crank vent doesn't need oil retrieval.
Old 07-24-2015, 12:18 PM   #8
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
for N/A single catch can (PCV to manifold) should be enough unless you track often. if boosted, i suggest getting a dual catch can.
Weapon86 is offline   Reply With Quote
Old 07-24-2015, 03:58 PM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
dual 42 draft design cans vented to atmosphere
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 07-25-2015, 09:37 AM   #10
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i dont really get the difference in what your asking lol im running the phastek catch can the separates the air and oil but vents the air back to the engine instead of the open vent. you still have to empty the can tho
IG-Joey_Soul
air oil separator, catch can, turbo
Perrin Air Oil Separator/Catch Can! FS Batman Engine, Exhaust, Bolt-Ons 8 03-31-2014 02:02 PM
Air Oil Separator? Do I need one? hmong337 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 21 12-31-2013 10:14 PM
FS: Cusco Oil Catch Can (Separator Type) howiedoit Engine, Exhaust, Bolt-Ons 4 12-02-2013 12:47 AM
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 ngabdala Engine, Exhaust, Bolt-Ons 11 06-10-2013 09:22 PM
Crawford Air Oil Separator JPxM0Dz Engine, Exhaust, Transmission 2 04-16-2013 09:33 PM
