Old 07-23-2023, 07:31 AM   #1
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
Frt stainless steel line query
I purchased a pair of frt HEL stainless steel brake lines but they didnt come with new banjo bolts just the washers. Am I ok the use the OEM bolts or would it be best to try and source new bolts from HEL.
Also any idea what size I would need to order please.
Thanks in advance.
Jonboy73 is offline   Reply With Quote
Old 07-23-2023, 10:01 AM   #2
N234
N234's Avatar
Drives:
I thought the banjo bolt was the fitting that is crimped to the end of the hose.
I reused the screw that secures the banjo to the caliper and the hardlines.
Sent from my Pixel 6 using Tapatalk
N234 is offline   Reply With Quote
Old 07-23-2023, 10:30 AM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Re-use the banjo bolts with the supplied new crush washers. Apply the OEM spec torque which I cannot recall but know it’s very low.
Edit: just checked the online manual. 13 #/ft is the torque value.
Enjoy!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-23-2023, 12:02 PM   #4
Jonboy73
Jonboy73's Avatar
Enjoy!
Perfect. Thank you.
Stainless Steel Brake Line Brands Michael Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 03-13-2017 06:05 PM
FS: New Goodrich Stainless Steel Brake Line Complete Set F1point4 Brakes, Suspension, Chassis 3 08-26-2015 04:34 PM
PHR Stainless Steel Black Clutch Line Powerhouse Racing Transmission and Driveline 5 10-07-2013 10:24 AM
Stainless steel brake line upgrade? 6-Shift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 06-13-2013 04:43 PM
