View Poll Results: What brand of stainless steel lines do you recommend?
Challenge 1 2.17%
Chase Bays 2 4.35%
Dezod 0 0%
Goodridge 14 30.43%
MTEC 2 4.35%
Spiegler 15 32.61%
StopTech 10 21.74%
Other Brand (State in your post below) 2 4.35%
Voters: 46. You may not vote on this poll
Old 03-11-2017, 10:01 PM   #1
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
Stainless Steel Brake Line Brands
Why yes, this is a thread about stainless steel brake lines and the various brands that are out there. I've done plenty of searching on installs and reviews but wanted to collectively gather what brands others have installed themselves or plan to install. I know that the Challenge and Dezod brands have the 90-degree bend on the rear lines but I am not sure if the Chase Bays, Goodridge, MTEC, Spiegler, or StopTech brands have those. If you know for sure, please annotate that in a post below.
The reason for this post is to gauge which brand that I may purchase. From reading other threads, some people state that this upgrade is not worth it unless I drive aggressively or take the car to the track. Since I am installing new pads (StopTech Street pads) and fluid, I might as well upgrade my lines at the same time. Seems like a fairly simple process. As of right now, I am leaning towards Dezod or Goodridge lines but I am not sure if the Goodridge lines have the bend in the rear lines.
What brand have you installed or recommend? Does your brand have the 90-degree bend on the rear lines? Any other comments to note?
▰▰▰ 2014 Scion FRS: Bagged & Wide
▰▰▰ INSTAGRAM: @frsmichael
▰▰▰ BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 03-11-2017, 10:31 PM   #2
ryoma
ryoma's Avatar
they should all have the bend if the lines are designed for our platform. I have Spiegler lines and they have the bend.
Old 03-12-2017, 03:00 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Eh, my two cents: your paying more just for a shiny new "protective" jacket over new brake lines.
Save yourself the money and buy dress up s.s. Selves to dress up your brake lines.
If you deem your current brake lines old and just feel like replacing them, and you got a bit of extra spending money, why not? Might as well get some go-fast stickers too.
Old 03-12-2017, 11:15 AM   #4
stevesnj
stevesnj's Avatar
Over the years ive learned SS lines are pretty much a waste of money. If your Master Cyl. is building up such a huge amount of hydraulic pressure than you have a bigger issue than brake lines
My 2016 Build thread
Old 03-12-2017, 04:24 PM   #5
RJasonKlein
RJasonKlein's Avatar
The Spiegler lines are, in my opinion, the best braided brake lines available for our cars.
Last edited by RJasonKlein; 03-12-2017 at 05:15 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 03-12-2017, 05:46 PM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I went to a local brake shop and they manufactured, in their workshop, ADR certified ss brake lines for me.
Old 03-12-2017, 05:47 PM   #7
Captain Snooze
Drives: Red Herring
What does that mean? Google Translate wasn't able to help.
Old 03-12-2017, 07:28 PM   #8
wparsons
wparsons's Avatar
You can absolutely feel a difference in the pedal between the stock lines and stainless lines.
They won't make you stop faster/shorter, but it does make the pedal more consistent, especially with less compressible pads.
As for the original question, I currently have stop tech lines from 2013 and they most definitely do not have the bend in the rear lines. They're a bit of a pain in the butt to get the one slider bolt off.
flickr
Old 03-12-2017, 07:54 PM   #9
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Originally Posted by wparsons View Post
You can absolutely feel a difference in the pedal between the stock lines and stainless lines....
Yep, but....
Like I told some kid long ago when he said the same thing, the difference you are feeling is because it's a new brake line. You get that same feeling if you replaced it with a brand new oem brake line.
It's like running in old worn close to its thread life tires, then getting brand new ones. Just they come in a fancy wrapper.
Old 03-12-2017, 08:40 PM   #10
J.Villain
J.Villain's Avatar
Drives: 2015 FR-S
I don't agree with that. The stainless steel braid keeps the rubber from expanding under pressure, even new factory lines do that. SS lines improve pedal feel and allow you to apply the braking you have a fraction of a second faster. Is it equivalent to a BBKor even better pads? No. But it is the bang for the buck winner as far as I am concerned.
If you do the SS lines do yourself a favour and get a set of speedbleeders at the same time.
J.Villain is offline   Reply With Quote
Old 03-12-2017, 09:17 PM   #11
Gunman
Drives: 2019 Mazda Miata RF
Exactly. I've worked with race teams, that won't run remote reservoir shocks, because of the flex in that short bit of hose, only hard mounted external reservoirs. Every little bit helps!
Gunman is offline   Reply With Quote
Old 03-13-2017, 03:13 AM   #12
Michael
Lovin' the Low Life
Michael's Avatar
Thank you all for the feedback. I've ordered the Goodridge stainless steel lines with the MOTUL RBF600 fluid and StopTech 308 street pads. I did not order speed bleeders but went with the Motive 107 Power Bleeder instead. Should arrive later this week but I won't have time to take care of this until the weekend after next.
Old 03-13-2017, 08:24 AM   #13
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by Mr.ac View Post
Yep, but....
You've never ridden a motorcycle have you? In that kind of situation you can tell exactly what happens when you change to a stainless line. To say they are dress-up items only is a falsehood.
Old 03-13-2017, 09:47 AM   #14
wparsons
wparsons's Avatar
Yep, but....
Are you suggesting my less than year old lines were so bad that they needed replacing already? I swapped to stainless lines when the car was ~8 months old and the difference was noticeable.
flickr
brake lines, brakes, stainless steel
FS: New Goodrich Stainless Steel Brake Line Complete Set F1point4 Brakes, Suspension, Chassis 3 08-26-2015 04:34 PM
FR-S/ SBRZ (2013 Al) -PTUNING Braided Stainless Steel Teflon Brake Line Kit!! Freddy@PTUNING Brakes, Suspension, Chassis 33 12-07-2013 02:01 PM
PHR Stainless Steel Black Clutch Line Powerhouse Racing Transmission and Driveline 5 10-07-2013 10:24 AM
Stainless steel brake line upgrade? 6-Shift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 06-13-2013 04:43 PM
