Old 02-07-2013, 06:07 PM   #1
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Question Stainless steel brake line upgrade?
Hey y'all, I am curious as to whether upgrading to stainless lines all around would be a good upgrade. I don't plan on making any other major brake upgrades but it seems like stainless lines are a good way to improve brake feel overall. Thoughts? Has anyone done JUST a stainless steel line upgrade?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 02-07-2013, 08:26 PM   #2
Pete156
I like to eat!
I did the stop-tech SS line upgrade along with new fluid. Eventually I will be changing front calipers and rotors.
Pete156 is offline   Reply With Quote
Old 02-07-2013, 08:46 PM   #3
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
I did the SS brake lines and also did the TiC MCB. The brakes feel way firmer. Feel like i can stop much faster. Planning on getting new fluid with new pads soon also.
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Old 02-07-2013, 09:06 PM   #4
polancd
Drives: a few
If your looking to upgrading your brakes, Pads would give you the best bang for buck. SS lines are a worthy upgrade but i would do the pads first.
polancd is offline   Reply With Quote
Old 02-07-2013, 10:10 PM   #5
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Yep, got basically the same setup (except a GrimmSpeed mcb and motul rbf600) and the pedal feel has definitely improved. Not as much fade when hard on the brakes as well.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 02-07-2013, 10:32 PM   #6
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Pads will have the greatest impact on feel. Lines will help, but you won't feel as much difference as a pad swap.
FYI...I'm about to run a Valentine's Day special on a Ferodo DS2500 pads, Spiegler SS lines, and AP Racing fluid bundle.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
MrTranxD (02-08-2013)
Old 02-07-2013, 10:44 PM   #7
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Do we have to take you to dinner first?
FT-86 SpeedFactory is offline   Reply With Quote
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
D1cker (02-08-2013), Ericc B (04-04-2013), wparsons (06-13-2013)
Old 02-07-2013, 11:04 PM   #8
chappys4life
Drives: 2013 frs
When are you starting that deal? Was thinking about Doug a similar package on my fr-s soon.
chappys4life is offline   Reply With Quote
Old 02-08-2013, 09:05 AM   #9
JRitt
JRitt's Avatar
I just put it up on the Essex blog...runs through next Friday.:happy0180:
www.essexparts.com
Old 02-08-2013, 09:06 AM   #10
JRitt
JRitt's Avatar
We can skip dinner and get to the good stuff.
www.essexparts.com
Old 02-08-2013, 09:52 AM   #11
mla163
Overthinking it
Drives: BRZ in CS
To improve braking, I would go
1. Pads
2. Fluid
3. Lines
4. Master Cylinder brace
Stop when it feels good
mla163 is offline   Reply With Quote
Old 02-08-2013, 10:50 AM   #12
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
I'm very satisfied with just the master cylinder brace (so far). Just a street driven car. Pedal travel has been significantly reduced.
Other mods like : pads, brake fluid, lines and even rotors ; depends on what you want.
Tires are also important and can help reduce stopping distance and handling/traction.
andrewFT86 is offline   Reply With Quote
Old 02-08-2013, 10:52 AM   #13
Kevin@RAD
Kevin@RAD's Avatar
Drives: Infiniti G35X
In my opinion, SS lines are a very good upgrade.
Decreasing the amount of expansion in those stock lines will greatly increase the response time of your braking.
Kevin@RAD is offline   Reply With Quote
Old 02-08-2013, 12:00 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
To improve braking, I'd go:
1. Tires
Then if you need higher temp pads or want more initial bite add pads and fluid if temps are a concern.
You should never be capable of boiling fluid on the street where most of these cars live, nor getting pad fade unless you are doing something wrong.
For a track car, I'd go:
1. Tires.
2. Essex Comp Sprint kit or similar with track pads and fluid
3. SS lines (I still haven't bothered to install mine) - for feel only which is the only benefit you'll see. There is no real performance benefit.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
WingsofWar (02-08-2013)
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
Dynosty Stainless Steel Brake Lines $99 Shipped Dustin@Dynosty Brakes, Suspension, Chassis 9 12-29-2012 09:56 AM
Goodridge Stainless Steel Brake Lines LavosTRD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-29-2012 06:37 PM
Stoptech Front Stainless Steel Brake Lines Pekingduck Brakes, Suspension, Chassis 1 10-21-2012 10:29 PM
Stainless steel brake lines taosracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-20-2012 04:09 AM
