Old 05-20-2023, 02:39 AM   #1
ruturaj001
Drives: BRZ 2023
Installing both 14mm and 16mm camber bolt
I have my first track day coming on Wednesday. So I am planned to do brake pads (Hawk HPS 5.0 for now but also have Ferodo DS2500 on order) and fluid (Castrol SRF) replacement tomorrow. I ordered and received SPC 81305 bottom camber bolt and whiteline KCA416 and planning to install them tomorrow as well. I booked free wheel alignment check appointment as Goodyear to just get number and see if something isn't horribly wrong afterwards.
Sharing to get feedback if I am doing something wrong. I might end up keeping the OEM pads, selling set of Hawk HPS 5.0 and installing Ferodo DS2500 when they arrive later than track day.
ruturaj001 is offline   Reply With Quote
Old 05-20-2023, 07:03 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Technically you can just take the lower OEM bolt that you are replacing with the 1305 and use it in the upper hole. That's the OEM crash bolt solution.
Either way that's roughly good for -2° camber range which will feel nice compared to OEM alignment specs.
The Following User Says Thank You to RToyo86 For This Useful Post:
ruturaj001 (05-20-2023)
Old 05-20-2023, 07:50 AM   #3
Ohio Enthusiast
Drives: 2018 BRZ
Toe would shift when adding camber so that would definitely will need to be addressed. Ask the tech to do a specific setting, not just in the green. Zero front toe and slight rear toe in is the recommended starting point.
All is good. As mentioned, most folks put camber bolts in the bottom and reuse the OEM bottom bolts in the top. This works but is less convenient to adjust and might give less camber. I'm running camber bolts top and bottom and it works very well.
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Old 05-20-2023, 09:05 PM   #4
ruturaj001
Drives: BRZ 2023
Thanks, that makes it complicated, I am busy since Monday and won't be able to get to real shop to get the job done. Goodyear won't be able to do a good job. Seems like I would do the job later.
Old 05-25-2023, 04:58 AM   #5
ruturaj001
Drives: BRZ 2023
What number would be slight rear toe? I am receiving brake pads tomorrow, so planning to install everything over weekend and get alignment checked, then if required find a specific shop to do the job.
Old 05-25-2023, 08:15 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
0.1 degrees total rear toe is fine.
= 6 arc-minutes =1mm = .040in. total rear toe if shop doesn’t use degrees.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Ohio Enthusiast (05-25-2023), ruturaj001 (05-26-2023)
Old 06-01-2023, 06:12 PM   #7
ruturaj001
Drives: BRZ 2023
I was able to get 2.4 degree negative camber on front. I think alignment guy did a great job with numbers.
The Following 3 Users Say Thank You to ruturaj001 For This Useful Post:
Ohio Enthusiast (06-01-2023), RToyo86 (06-01-2023), ZDan (06-06-2023)
Old 06-01-2023, 08:14 PM   #8
Ohio Enthusiast
Drives: 2018 BRZ
I wish alignment shops around here were that good... Very nicely done!
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
Dzmitry (06-01-2023), ruturaj001 (06-01-2023)
Old 06-01-2023, 08:49 PM   #9
ruturaj001
Drives: BRZ 2023
I was surprised too and charged me just 100 before tax.
The Following User Says Thank You to ruturaj001 For This Useful Post:
Old 06-01-2023, 08:50 PM   #10
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I'm nervous in this regard for a future shop. Knew one fantastic one about 30 mins from my area that did alignments and suspension work. They got my camber and toe alignments to the DOT with EXACT values that I asked for. It was a lovely sheet of paper to look at. Unfortunately they split and closed through COVID and now I only know typical good local shops that my friends recommend... which based on seeing their results, I just know it's not going to be quite the same.
Dzmitry is offline   Reply With Quote
Old 06-01-2023, 10:00 PM   #11
ruturaj001
Drives: BRZ 2023
That sucks. I had this awesome shop near me when I lived in Raleigh, the guy happily talked with me about sway bar install, did amazing job and didn't bankrupt me. I moved out of the state few years ago.
Dzmitry (06-07-2023)
FS: NEW WHITELINE CAMBER BOLT KIT 16MM KCA416 Imperial Stormtrooper Brakes, Suspension, Chassis 0 05-05-2017 04:50 PM
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) Joesurf79 Brakes, Suspension, Chassis 2 01-13-2017 05:03 PM
FS: 14mm camber (crash) bolt frslee Brakes, Suspension, Chassis 1 05-06-2015 10:32 AM
WARNING: DO NOT use 14mm OEM camber bolt in slotted hole switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 10-31-2014 03:56 PM
Help with 16mm eccentric camber bolt drift86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-11-2014 12:09 PM
