Glorious BRZ Master Race
Drives: Subaru Libird
WARNING: DO NOT use 14mm OEM camber bolt in slotted hole
*EDIT*
Jump to lesson learned in post #24 below. -- Does the 14mm OEM camber bolt cancel out or add positive camber to any negative camber afforded by a slotted upper hole? I had stock struts with camber bolts in the upper holes to yield -1.2 camber. I installed ST coilovers with slotted upper holes, used the same 14mm bolts top and bottom, and held the rotors tilted inwards as I torqued down like I did before to maximize negative camber. That yielded 0 and +0.4 camber. I'm going to try swapping in the stock 16mm bolts up top in hopes of getting negative camber. Can anyone explain how camber came out zero/positive? I'm having difficulty picturing it in my head.
AutoX-10/10ths every run
Ride height variation? I believe that as the front is compressed it gains positive camber.
Drives: FRS(sold), AP2, R35, FJC, ED9
i was able to get -1.2 in the fronts using smaller bolt in the top hole.
#4 | |
^Are you using those with slotted upper holes? Because I also got -1.2 camber when I used OEM camber bolts on my stock struts. But the same set of camber bolts on my new slotted hole coilovers yield 0 camber (the same 14mm bolts x 4 all around).
And this guy in another thread posted this regarding coilovers with a slotted top hole without explaining why:
That Guy
Drives: 2013 asphalt FRS MT
Do the OEM bolts have an eccentric to allow easy adjustment, or is it just a smaller bolt? If they have an eccentric you may have assembled them incorrectly or adjustment the wrong way.
They're not eccentric, just smaller 14mm instead of stock 16mm.
Sounds like something went wonky during the install of the knuckle bolts... a slotted hole + smaller bolts top and bottom should get you a lot of negative camber if done right.
How sure are you that you tilted the knuckle the right way when tightening the bolts? To me it sounds like the bottom bolt slipped inwards as well. To make your life easier, run the OEM bottom bolt and the smaller top bolt with the slotted strut and you should still get lots of camber.
Another forum seems to concede that a round shaped camber bolt should not go into a slotted hole due to potential slipping: http://m.fitfreak.net/forums/showthr...465&styleid=15
No clear explanation on why but some comments imply it could cause slippage.
#9 | |
#10 |
And I torqued the bolts to the 114 ft-lbs spec in all 3 installations.
#11 |
That Guy
Did you install the top hats in the wrong orientation?
The sides of the hole aren't what prevent movement in this system, friction and clamping force do that. so, slotted struts with camber bolts shouldn't slip any more then normal struts and camber bolts. |
#12 |
Drives: 2013 FR-S, 2012 MCS
Sorry to de-thread but where is everyone is buying these from? Subby dealer?
#13 | |
^Yes, the part number is floating around on this forum.
But the clamping pressure is less on slotted struts due to the decreased clamping area given the same torque spec.
#14 | |
Professional Smartass
Drives: White Out FRS
| Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
| Camber bolt on KW V3 | derek1ee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-25-2017 11:21 AM |
| slotted upper strut hole | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 11-22-2013 10:31 PM |
| Camber bolt help | oofie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-22-2013 01:36 PM |
