Old 12-31-2016, 02:48 PM   #1
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :)
Two sets of camber bolts to hook you up with Max negative camber the cheap, dirty, grimey (debatablely safe?) way. Santa not bring the camber plates you wanted? No worries! I got -2.5 degrees static negative camber running both sets on factory strust and RCE yellow springs-resulting in much better tire wear on track (be sure to zero the toe afterwards.) Track rats on a budget, rejoice, and send me $26 total to get both sets of perfectly functional bolts, shipped USPS priority flat rate to you anywhere in the US of A. Happy new apex slaying years to you!
Joesurf79 is offline   Reply With Quote
Old 01-01-2017, 12:37 PM   #2
Joesurf79
Joesurf79's Avatar
Sale pending to ls1ac
Old 01-13-2017, 05:03 PM   #3
SMOOTHY
Drives: '13 BRZ
Are these sold already?
SMOOTHY is offline   Reply With Quote
FS: KCA416 Whiteline Camber Bolts 16mm Asidrive Brakes, Suspension, Chassis 1 12-23-2016 03:11 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
