Drives: BRZ 2023
Installing both 14mm and 16mm camber bolt
I have my first track day coming on Wednesday. So I am planned to do brake pads (Hawk HPS 5.0 for now but also have Ferodo DS2500 on order) and fluid (Castrol SRF) replacement tomorrow. I ordered and received SPC 81305 bottom camber bolt and whiteline KCA416 and planning to install them tomorrow as well. I booked free wheel alignment check appointment as Goodyear to just get number and see if something isn't horribly wrong afterwards.
Sharing to get feedback if I am doing something wrong. I might end up keeping the OEM pads, selling set of Hawk HPS 5.0 and installing Ferodo DS2500 when they arrive later than track day. |
#2 |
Drives: 17 Asphalt 86
Technically you can just take the lower OEM bolt that you are replacing with the 1305 and use it in the upper hole. That's the OEM crash bolt solution.
Either way that's roughly good for -2° camber range which will feel nice compared to OEM alignment specs. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | ruturaj001 (05-20-2023) |
#3 | |
Drives: 2018 BRZ
All is good. As mentioned, most folks put camber bolts in the bottom and reuse the OEM bottom bolts in the top. This works but is less convenient to adjust and might give less camber. I'm running camber bolts top and bottom and it works very well. |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | ruturaj001 (05-20-2023) |
#4 |
Drives: BRZ 2023
Thanks, that makes it complicated, I am busy since Monday and won't be able to get to real shop to get the job done. Goodyear won't be able to do a good job. Seems like I would do the job later.
#5 | |
Drives: BRZ 2023
#6 |
Drives: '23 BRZ
0.1 degrees total rear toe is fine.
= 6 arc-minutes =1mm = .040in. total rear toe if shop doesn’t use degrees. |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | Ohio Enthusiast (05-25-2023), ruturaj001 (05-26-2023) |
#7 |
Drives: BRZ 2023
I was able to get 2.4 degree negative camber on front. I think alignment guy did a great job with numbers.
| The Following 3 Users Say Thank You to ruturaj001 For This Useful Post: |
#8 |
Drives: 2018 BRZ
| The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | Dzmitry (06-01-2023), ruturaj001 (06-01-2023) |
#10 |
Drives: 2018 Subaru BRZ Limited with PP
I'm nervous in this regard for a future shop. Knew one fantastic one about 30 mins from my area that did alignments and suspension work. They got my camber and toe alignments to the DOT with EXACT values that I asked for. It was a lovely sheet of paper to look at. Unfortunately they split and closed through COVID and now I only know typical good local shops that my friends recommend... which based on seeing their results, I just know it's not going to be quite the same.
#11 | |
Drives: BRZ 2023
| The Following User Says Thank You to ruturaj001 For This Useful Post: | Dzmitry (06-07-2023) |
| FS: NEW WHITELINE CAMBER BOLT KIT 16MM KCA416 | Imperial Stormtrooper | Brakes, Suspension, Chassis | 0 | 05-05-2017 05:50 PM |
| SPC 16mm and 14mm camber bolts - dirty grimey kid's camber dream :) | Joesurf79 | Brakes, Suspension, Chassis | 2 | 01-13-2017 06:03 PM |
| FS: 14mm camber (crash) bolt | frslee | Brakes, Suspension, Chassis | 1 | 05-06-2015 11:32 AM |
| WARNING: DO NOT use 14mm OEM camber bolt in slotted hole | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 66 | 10-31-2014 04:56 PM |
| Help with 16mm eccentric camber bolt | drift86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 09-11-2014 01:09 PM |
