Drives: 2013 FRS
need ECUTEK tune for edelbrock SC
I installed my SC on a 2018 BRZ and my 2013 MAP is not compatible, does anyone have a MAP that I can use just to get him on the road to Delicious?
Drives: brz 2017 hksv2
stock tune only works with stock map, if you ve Planned to drive witb stock tune, you won t be able even to crank the engine up without stock MAP
#3 | |
Drives: WRB BRZ
Correct 2013 tunes are not compatable with 2018 tunes/car If you getting deliceous tune then deliceous should supply you with base map |
Drives: 2013 FRS
Delicious wants 350 for a basemap and then 1200 for his dynotune. He should have to double dip. Just need something to get him to Delicious.
Are you talking about a base tune or a map sensor?
Drives: 22 BRZ limited
Base tune I'm guessing. Just something to get down the road to the tuner.
#7 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Tow it there.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
| The Following User Says Thank You to brandonblt2 For This Useful Post: | Teseo (05-17-2023) |
Drives: 2016 Scion FRS Release Series 2#439
OR contact CSG. Zach will hook you up with an e-tune. Why do you need to go to Delicious?
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
I don't. I was replying to someone's questions.
#10 |
@Smaay Slap the original stock tune on it and limp it down the road with the original accessory belt. So, just don't hook up the supercharger belt and go easy on it.
#11 |
Drives: Q5 + BRZ + M796
I think if you didn't change injectors then you can drive it on the stock tune. There is a bypass valve, so there shouldn't be any boost unless you accelerate quick enough to get it into boost. It just takes some control of your right foot.
#12 | ||
You can't swap ECUs because of the model year because of the engine changes (maybe unless you both have automatics because I think the engines are the same), but I'm assuming you are trying to sell or use your tune on his car, which won't work. You need a tune, an ECUTEK license and you need the dongle/cable, and when a tuner builds a tune, you provide your vehicle's ECU number and ECUTEK license and everything is update somewhat permanently on the ECU. In this way, the license is tied to your ECU once it gets "used" and the tune file coded to that ECU and license number, so only the author of the tune could open or alter the file for you to change it to another license and ECU, but they wouldn't do that. Just to buy the ECUTEK license is $350. Delicious Tune is either saying that, or they are saying that if the person wants their base map it will be $350 (see below). The base map is not a back and forth full e-tune; it is just to get the car running with basic settings for your setup, so if you have larger injectors or changed the fuel pressure regulator or something. Looks like half the price ($175) can be applied to a dyno session later. https://www.delicioustuning.com/node/340 Quote:
#13 |
Drives: 2013 FRS
guess i leftout a ton of details. Yes I sold the SC and installed it on another car, which was a 2018. obviously the 2013 and 2018 are not compatible so I couldnt load my tune into his car.
the buyer drove all the way to my place in So Cal from CANADA!!!!! he had the appointment and a deposit paid to delicious for a full tune. delicious wanted to charge him 350 bucks for a base tune just to get him down there and wouldnt credit that to his 1200 dollar tune. I say thats pure BULLSHIT! Luckily Edelbrock came through and provided a tune since he already had an ECUTEK. to major props to them... So i want to doubledown on delicious, for charging 350 just for a tune to get down there is effing WRONG!. When I got my WRX tuned for all my mods, the shop was happy to provide me a tune to get me to the shop and then do all the fine tuning on the dyno. Im sure the new owner will post his side of the story. |
#14 |
Tunes take time, time costs money. They are busy enough that if you do not get a tune there is someone right behind you throwing money at them. Capitalism baby!
The stock tune should work unless you have changed out the injectors or MAP sensor. You could put the stock MAP sensor in to get it down the road, just do not get into boost. |
| Edelbrock stock tune file | Windycity | Forced Induction | 11 | 10-14-2022 01:17 AM |
| 17 BRZ with Edelbrock SC tune options | snowtaipan | Software Tuning | 9 | 06-30-2021 09:04 PM |
| OFT Edelbrock Tune | Gloonge | Software Tuning | 2 | 08-04-2020 05:35 AM |
| Edelbrock SC Stock Tune with Full Exhaust | Shogunwave | Forced Induction | 20 | 01-21-2019 04:47 PM |
| Edelbrock Tune | gt86yasss | Software Tuning | 13 | 10-18-2018 02:56 PM |
