Old 06-22-2021, 07:26 PM   #1
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
17 BRZ with Edelbrock SC tune options
Hey all, I'm living near Clarksville TN and I'm trying to find a tuner who can drop an ECUTek tune in me that can support 91-93 octane. My inquiries have gotten... Mixed results.
The goal is to reach around 300HP with everything stock aside from the SC and tune. What I'm seeing is that the injectors and fuel pump pretty much max out at that point.
I'm also having a hard time finding a shop that can do a tune that supports both 91 and 93. I frequently move between states and need the flexibility.
Is this an unrealistic goal, and does anyone know anybody in the area that can get me hooked up?
snowtaipan is offline   Reply With Quote
Old 06-23-2021, 12:29 AM   #2
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I can't help with finding tuners local to you, but if you mean 300 WHP, my understanding is that won't be possible on 91-93 octane with that setup (all stock + Edelbrock SC). For 300 crank HP, it may be feasible depending on how you look at / interpret the dyno numbers.
Stock BRZ's apparently usually put down 160-170 WHP on the dyno, so if you're talking a 46.3% increase (because 300 is 146.3% of 205, so 234-249 WHP), you need to gain 74-79 WHP. You *should* be able to achieve this pretty comfortably with a remote tune from Delicious Tuning from what they claim.
If you're talking about a 95 hp increase (because 300 is 95 more than 205, so 255-265 WHP), then I think that *may* be out of reach without a custom tune.
Of course, this is all just from what I've read / researched, not first-hand experience. I'm planning to supercharge my BRZ (either Harrop or Edelbrock) with everything else stock like you, so I've read everything I can get my hands on regarding that combo!
Tatsu333 is offline   Reply With Quote
Old 06-23-2021, 02:06 AM   #3
steve99
Supplied edelvrock pully is good for about 12psi boost.
12 psi on 91 is probably not ideal id stick to max 10 psi
93 might be ok depending on quality of fuel.
unfortunatly you csnnot alter boist on the fly like turbo so id suggest getting the one size bigfer pully and sticking to 10 psi max boost.
Stock pump and injectors will ve fine at 10 psi on petrol you can wven run E85 with flex kit at that boist stock injectors and pump.
300 wheel hp might ve a bit of a stretch if you want it safe.
As for 91 and 93 thats easily done with ecutek multi map tune you can just make map1 91 and map 2 93 and do whatwver with the other two say a valet mode or add ecutek features like launch ffs auto blip or pops and crackles
Old 06-23-2021, 01:52 PM   #4
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I am seeing 9PSI for the stock pulley on the Edelbrock:
Outside Pulley Diameter 3.25 in
Maximum Boost Pressure 9 PSI
https://www.edelbrock.com/e-force-su...2-0l-1556.html
I am on the stock pulley with 92 and putting down 246whp and 220ft/lb with a custom tune (catless header, too)
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 06-24-2021, 12:17 AM   #5
steve99
Hmm strange ive done coiple of edelbrock and on the 3.25 was getting to 11 to 11.5 or so boost round 7000 , has to go to 3.5" pulley to keep it below 10 psi cars had catless header and hi flow cat frontpipe
BrahmaBull1990 (06-24-2021)
Old 06-24-2021, 12:22 AM   #6
steve99
sane car with 3.5" pulkey boost artound 9-10 psi
Old 06-29-2021, 07:36 PM   #7
There is no way for the car and thus, the tune, to know what octane is in your car. You will need to manually switch calibrations for the octane.
If you run 91 on the 93 calibration, you can and will, have a bad time.
Old 06-30-2021, 03:09 AM   #8
steve99
https://www.romraider.com/forum/viewtopic.php?t=1840
In the 32 bit ecu it works pretty well the same , DAM is equilvant to IAM or advance multiplier and is 0-1 instead of 1-16.
While you would not totally rely on the IAM and knock control system on a boosted car, if set up correctly it will save you if you fuel up with a lower octane fuel by mistake thats basicly what the the subaru engineers designed it to to.
You may need to move more timing into the Knock correction advance tavle from the base table this make the iam reduction more aggressive at global timing reduction in event of knock detection .
You can also make the iam reduction( ie knock detection )make the car run richer. The standard algorythyms in wcu set up to do this as knock reduction strategy.
Again not ideal but there is compensation there to cope with bad fuel or lower than expected octane unfortunatly ive seen tunes that dont take advantage of this or tuners that activly try to defeat this logic for some reason like removing timing from the knock advance table or zeroing the fuel compensation map.
Another strategy that helps is do your tune at IAM advance multiplier initial at 1. The at the end set it back to 0.7 like factory so the ecu needs to detect minimal knock it will increment the iam to1 and full timing.
Old 06-30-2021, 03:18 PM   #9
Just remember what has to happen first, for that to even start working.
Definitely not ideal.
Old 06-30-2021, 10:04 PM   #10
steve99
Correct
Hence its good practice to do what the factory does and set the iam initial to 0.7 if your unsure of fuel quality that end user will have.
That way at each startup the ecu uses reduced timing and after some running with minimal knock detections will increment iam to 1 if fuel good.
Not all fuels are created equal even fuel rated at 93 from different sources can perform quite differently especially on boosted cars.
USA 91 can is some cases be better than say Canada 93.
The subaru knock control strategy works well if set up correctly or not actively knobbled by tune.
Pretty well no tune will be 100% knock detection free all the time, there is an acceptable! level of knock detection over which the setting in the ecu will quite aggressivly reduce timing and richen fueling if set up correctly.
Ecutek have also added addition of boost reduction ( turbo) on IAT , knock, coolant temp.
https://cobbtuning.atlassian.net/wik...ock+Monitoring
OFT Edelbrock Tune Gloonge Software Tuning 2 08-04-2020 06:35 AM
Edelbrock and UEL tune. Open flash tablet? casing Software Tuning 10 03-26-2019 07:04 AM
Edelbrock SC Stock Tune with Full Exhaust Shogunwave Forced Induction 20 01-21-2019 05:47 PM
Edelbrock Tune gt86yasss Software Tuning 13 10-18-2018 03:56 PM
Edelbrock Supercharger w/ 500$ rebate + Free Tune + discount! -Phil Forced Induction 0 12-12-2016 06:29 PM
