Drives: 2013 Scion FRS
Edelbrock SC Stock Tune with Full Exhaust
Just like the subject says, I just installed (actually in the process of installing) an Edelbrock Supercharger. As anyone with the kit knows, it comes with a stock base tune. After the fact, I have a full exhaust on my car. As long as I don’t drive the piss out of it, will I be ok? I don’t want to run super lean and melt my pistons lol. Any feedback would be greatly appreciated. I know a lot of people are running a delicious tune and that’s in the future but unfortunately ran out of funds for now...
The stock Tune is meant for a stock car. I am guessing it would but its gonna run like shit. You spent all that money, find a way and scrape together the extra bit for the flash and go tune.
2013 Series 10 FRS #553
#3 | |
That’s why I’m wondering if it’s worth it or at least something I can sit on for a while. I appreciate your thoughts and advice none the less! |
Drives: blue - Cosworth SC stage 3.0
probably best to get in touch with Edelbrock and ask their advice
however I would say if you have a full aftermarket exhaust then 95% of these flow better with less back pressure than the stock exhaust as a consequence a stock ECU tune will be very safe on an aftermarket exhaust and should work just fine it just means that there's power waiting to be had once you do tune it |
#5 | |
Drives: 2018 BRZ tS
As another said, you’ve already spent so much to get this far. You are messing with FI, do it right, or it’ll definitely come back to haunt you. |
You said full exhaust which in my mind means a header as well. If that is the case you need a custom tune.. if you have stock header then the stock/base tune will work
jflogerzi nailed it
Rust bucket enthusiast
This is like having a baby and then complaining that you have to buy clothes for it. A tune is an integral part of your car's health and performance. If you want your baby to live life naked, it will be sickly, and do terribly in life. But at least you saved money on clothes, right?
I appreciate all feedback a I recognize the fact that I will need to get the tune but thats not what I am asking for in response. I’m asking for opinion on if you think it is safe to drive the car for a few months prior to getting the tune. Anyways, I appreciate all the feedback.
#10 | |
Drives: 2018 BRZ tS
The risk vs reward just isn't there. The risk - blown motor. The reward - drive a poorly tuned vehicle that won't make it feel worth the investment in the SC for a few months. For reference, I bought my JRSC Kit w/ Oil Cooler back in October, and slowly began piecing together the rest of the parts I needed to make it run as safely and smoothly as possible over the next few months (i.e., Catch Can , 4 Bar MAP Sensor, BPV, Flex Fuel, injectors, etc.). Then the tune is an additional expense on top of all of that. Your best bet. Hold off on install until you get the tune, and whatever additional supporting mods you need (e.g., JR Dual Rad/OC, Catch Can, DT Dbox). Then do the install for everything all at once. It may also help if you define what "safe" means to you. Does "safe" mean, I don't have to worry about it blowing up every time I turn it on or step on it, or is "safe" referring to long-term engine life and performance. |
#11 |
There's a reason the overwhelming response you're receiving is to get a tune. There's a reason we feel this way. There's a reason your car needs a tune.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | J1Avs (01-20-2019) |
#12 |
Drives: 14 BSP Edelbrock BRZ
Just giving the car enough throttle to leave a stop drops the vacuum level enough to start to close the bypass valve and create positive pressure.
If you are set on doing this I would recommend removing the vacuum actuator and tying the bypass valve open with cable ties. It is the only way you're going to stay out of boost. In that scenario you will probably be in the range that the ECU can compensate as long as you stay out of the throttle. But like everyone else said, spend the $400 and get the tune... |
#13 |
Ok, I appreciate the overwhelming response. I’ll give delicious tuning a call tomorrow to get a little bit more information. This is my daily driver so I want to understand a little more and do som research but I’ll try them out. If anyone has an experience to share that has a similar setup with an edelbrock SC. I would appreciate the feedback.
#14 |
You will be in good hands with them. They know our platform really well.
| Help! Tank full of E85 2017 Stock BRZ what OFT tune to use? | D4FD | Software Tuning | 41 | 10-30-2017 04:06 PM |
| Edelbrock Supercharger w/ Tune *1 left in stock* $5399.99 Shipped! | Kami Speed | Forced Induction | 3 | 03-13-2017 03:11 PM |
| Can I run a full exhaust without a tune | Scion1738 | Engine, Exhaust, Transmission | 5 | 11-23-2015 10:03 AM |
| Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? | fooddude | Engine, Exhaust, Transmission | 39 | 12-15-2013 02:05 PM |
| T1R Full Exhaust re-dyno x DRIFT OFFICE TUNE !!!! | AJ PwR | Engine, Exhaust, Transmission | 19 | 04-25-2013 05:10 PM |
