Old 04-26-2023, 06:25 PM   #1
Humphrey
Drives: 2014 Subaru BRZ (JSRC)
Traction control on left turns
Traction control kicks off on left turns at a much lower angle of a turn compared to right turns. The car turns on traction control and jerks me and stops me from turning further.
I recently upgraded to 17x9 gramlights and continental extreme contacts dws06 plus.
I had the car put on the alignment machine and have reset the VSC memorization but the problem is still here.
Not only have I driven this car at a point where it felt fine on left turns. I also have another BRZ that has worse tires and the car does nothing similar.
Maybe someone can spot an issue in the alignment below but I’ve been told it’s ok.
Here’s some other posts with a similar problem:
https://www.ft86club.com/forums/showthread.php?t=116104
https://www.ft86club.com/forums/show....php?p=3254205
https://www.ft86club.com/forums/show...=149411&page=2
Humphrey is offline   Reply With Quote
Old 04-27-2023, 12:13 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Are we sure that what is shown on the screen isn't the "before" pictures of the alignment before adjustments were made?
I can't imagine any competent alignment tech sending a car out the door with that as the final alignment.
Originally Posted by humfrz
I'm old and lazy
Old 04-27-2023, 12:18 PM   #3
Humphrey
It is the after.
I don’t have any camber adjusters so they couldn’t correct the camber.
Old 04-27-2023, 12:20 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Originally Posted by Humphrey View Post
It is the after.
Ok, well ignoring the camber then, they could/should at least have adjusted the left rear toe and zeroed it out.
Maybe the issue is that the alignment tech forgot to reset the steering angle sensor?
I'm old and lazy
Old 04-27-2023, 12:55 PM   #5
Humphrey
I’ll get back to you with some more information asap
Old 04-27-2023, 01:02 PM   #6
Racecomp Engineering
Yeah it's "in the green" for total toe, but uneven left to right which is not great.
- Andrew
Old 04-27-2023, 02:47 PM   #7
strat61caster
strat61caster's Avatar
I wouldn’t be thrilled with that alignment but it shouldn’t be awful. Check tire pressures and take it to a different shop imho, some shops have alignment racks way out of calibration and the fact that they didn’t at least try and even out the toe in the back isnt a good sign.
ineedyourdiddly
Old 04-30-2023, 10:43 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
Alignment doesn't look great. Is your car stock except for the wheels?
1974 TA22 Celica
2013 86 GT
Old 05-01-2023, 08:07 AM   #9
marco_mc22
Drives: Toyota 86
I'd start the trouble-shooting fixing that uneven front and rear toe, as for the camber yeah it's not ideal but still fine to me; also, find a decent shop, no matter if they use lasers or strings, it has to be a decent shop with a good tech and while your car is lifted check for any lose or worn part in the rear kinematics.
Then if this will not fix it...except for the wheels which other mods you have?
If you're on coilovers make sure you have a proper ride height with enough rear droop travel, too little travel can cause this problem (it happened to me) but it should't happen only on left turns.
Did it start as soon as you got your new wheels?
marco_mc22 is offline   Reply With Quote
Old 05-01-2023, 08:34 AM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
Could something like this be caused by poor corner weighting?
Old 05-01-2023, 11:08 AM   #11
Humphrey
I will.
Yeah it started as soon as I got new wheels and tires but I really can’t figure out how it could be that at this point.
I was on stock coil overs then bought aftermarket HKS hoping it would help the problem but didn’t.
Old 05-01-2023, 01:33 PM   #12
Humphrey
Jackson racing C38, JDL UEL Catted header, JDL Dual resonated Over pipe/Front pipe combo, Ark Grip Catback, HKS Hipermax GT Coils
I just bought the whiteline front camber bolts and rear LCAs to adjust camber.
Edit:
I've also rotated my tires and I re-torqued my rear axle nuts.
Old 05-01-2023, 01:37 PM   #13
marco_mc22
Drives: Toyota 86
I will.
Well, no need to say that a wheel swap with oem ones would be the first thing to do. Double check that tires are installed correctly too, same rim width left to right too if you used staggered wheel
Which kind of LCA you bought?
Old 05-01-2023, 01:41 PM   #14
Humphrey
Edit:
Here's my mods and the LCAs I bought. You're definitely right to swap back to the OEM wheels, I'll do that ASAP.
Traction control on left turns Humphrey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-01-2023 05:48 PM
Help diagnosing weird left turns. PikachuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-25-2022 05:19 PM
Traction control turns on crazy when turnin left but not right? Nah Issues | Warranty | Recalls / TSB 58 09-13-2020 02:57 PM
Humming noise on left turns. kphan Issues | Warranty | Recalls / TSB 10 10-27-2016 11:49 AM
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 07:38 PM
