Old 07-20-2015, 01:55 PM   #1
loading_please_wait
Drives: 2015 Scion FR-S
New front sway, a little unstable on left turns
I installed a Hotchkis front sway with Perrin endlinks. I noticed on left turns, the car feels slightly unstable. On right turns, it's fantastic.
I noticed this first today on a left turning highway sweeper. The instability also popped up on a quick left hand turn on city roads. It's like the car is wanting to drift out of the line I decided to choose. The closest analogy I can think of is the feeling of torque steer.
I torqued all bolts to spec so I'm not sure if that may be an issue.
The only different things I've done was I had to rethread one hole and insert a helicoil into the crossmember that the driver's side sway bar mounting plate attaches to.
I also grabbed a replacement bolt from Lowe's to replace a broken bolt.
I'm also unsure if this is the new tires that were just put on either. Perhaps an alignment is needed?
Perhaps the sway isn't perfectly centered? Could the sway being not centered cause this? It seem centered to me. But I can check again.
loading_please_wait is offline   Reply With Quote
Old 07-20-2015, 03:41 PM   #2
fika84
fika84's Avatar
Sounds like you're getting understeer. Is the front sway bar thicker than the one you had previously? Why do you have broken and stripped bolts? Alignment couldn't hurt, how much do you weigh? You could be the deciding factor on why right hand turns (with your weight on the outside tire) are working better than left hand turns (where your weight is on the inside tire).. How many miles do you have on the tires? What kind of tires are they?
fika84 is offline   Reply With Quote
Old 07-20-2015, 07:38 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
It would be hard to get the Hotchkis front bar off center, it has welded on centering collars. End links the same length?
Gunman is offline   Reply With Quote
Kit Turns Toyota GT 86 into Lexus Front Lookalike mark0006 Scion FR-S / Toyota 86 GT86 General Forum 35 05-23-2015 09:10 PM
WTB: OEM Control Arms: Front Left & Back Left norcalpb Want-To-Buy Requests 0 02-26-2015 08:55 PM
weird noise from front left impossible Issues | Warranty | Recalls / TSB 14 11-07-2014 11:22 PM
Need front left oem wrb fender suboobaru Southern California 1 02-08-2014 11:38 PM
Unstable feeling Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2013 11:06 AM
