Old 10-25-2016, 03:19 PM   #1
kphan
Drives: 2014 Subaru BRRRZ
Humming noise on left turns.
I have an pulsing humming noise whenever I am turning left from the LEFT wheel driver side. You can feel a slight vibration. I looked up to see if this was a wheel bearing issue but it seems like it would be the right wheel that should be making the noise. It pulses which make it seem like a tire issue and the rate of pulse increases with speed. I recently did get suspension installed. Anyone have any ideas what it could be? Thanks!
kphan is offline   Reply With Quote
Old 10-25-2016, 03:22 PM   #2
swarb
You should mention ALL the parts you have installed.
What have you checked?
Did you get an alignment after the suspension install?
Old 10-25-2016, 03:37 PM   #3
kphan
Was in a rush to post and forgot to specify. All that was installed were TRD springs. I had a mechanic friend check out alignment. It could possibly be that, I just wanted input to make sure before I go and do it.
Old 10-25-2016, 03:47 PM   #4
swarb
I am asking what other parts do you have installed? Wheels? etc? What do you mean by "I had a mechanic friend check out alignment." ?
Get an alignment...
The Following User Says Thank You to swarb For This Useful Post:
kphan (10-25-2016)
Old 10-25-2016, 03:51 PM   #5
humfrz
I suggest you get an alignment and mention to the tech what the car is doing.
humfrz
kphan (10-25-2016)
Old 10-25-2016, 03:58 PM   #6
kphan
Only ideas I have are, wheel not mounted correctly, wheel balance off, tire pressures, suspension loose from install, alignment off... , or other parts...
Everything is stock including wheels. Only modification are TRD springs. What I mean by mechanic friend is that he works at a shop. He lifted the car, checked the alignment of wheels and told me I was good to go. I've never done an alignment myself so I do not know what that entails.
Tire pressures are normal levels. Car has 23k miles. Sounds are a like "Whoombb.......whooomb....." etc. It happened after installation of the springs.
Old 10-25-2016, 04:41 PM   #7
strat61caster
strat61caster's Avatar
Front or rear and at what speed?
Could just be hearing the LSD doing what it's supposed to.
ineedyourdiddly
Old 10-25-2016, 09:19 PM   #8
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Did this "mechanic friend" scan the wheels themselves? Give you a telemetry sheet of the toe and offset? Or did he just look at it for a minute and say "yea, it looks good to me."?
If the alignment isn't correct than there could be possible rubbing issues either with suspension components or with the fender itself. Not saying that's exactly what's happening but you shouldn't take something like wheel alignment so lightly.
And who installed the TRD springs?
Silver Cervy is offline   Reply With Quote
The Following User Says Thank You to Silver Cervy For This Useful Post:
kphan (10-27-2016)
Old 10-27-2016, 09:34 AM   #9
kphan
Front. It typically is more noticeable at higher speeds but can be heard on slower turns as well. It only happens when the wheel is positioned left at any degree.
Old 10-27-2016, 09:39 AM   #10
kphan
Yeah no information on it. Just trusted his judgement based on his history. I will probably get an alignment here based off of everyone's suggestion and hope it fixes the issue. I installed the springs myself but its definitely not the first time I've done it.
Thanks!
Old 10-27-2016, 11:49 AM   #11
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Yeah you need an alignment. It might not be what's causing the issue, but it's a good first place to start, and something you need anyhow!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Fan static/humming noise Zhangy Issues | Warranty | Recalls / TSB 8 08-26-2017 09:47 PM
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 07:38 PM
Humming noise while driving maylchi Issues | Warranty | Recalls / TSB 9 03-13-2015 01:29 AM
help!! weird humming noise?? sid94 Issues | Warranty | Recalls / TSB 3 05-17-2014 12:16 PM
Humming noise from the rear/gas tank? Turbo95eg6 Issues | Warranty | Recalls / TSB 3 11-30-2013 04:10 PM
