Old 03-12-2023, 08:45 PM   #1
nickebanks
Drives: 2016 Scion FR-S
Exclamation Car dies at idle
Recently tuned by Delicious on their stage 2 tune. Had no issues the first few days. I'm not sure at all what the issue could be. This only happens after RPMs increase and drop back down. Does not happen when coasting in neutral or resting at idle.
Idle log: Giving the car a little bit of gas at idle here, not too sure what to look for here but I see the voltage dropping super low as the car almost stalls.
https://datazap.me/u/nickebanks/log-...?log=0&data=16
Driving log: Not sure if there's anything else to look for here. There are a couple points in time where I almost stall highlighted by the voltage dip.
https://datazap.me/u/nickebanks/log-...=0&data=6-9-16
nickebanks is offline   Reply With Quote
Old 03-12-2023, 08:51 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Well what did Delicious say?
The Following 2 Users Say Thank You to Pat For This Useful Post:
humfrz (03-13-2023), whataboutbob (04-22-2023)
Old 03-29-2023, 01:51 PM   #3
arxm
Drives: 2013 FR-S, 2023 BRZ
im having the exact same issue, delicious tune for my jackson racing c38 kit. Car will die if im feathering the clutch to reverse for example, as soon as I want to stop, I clutch in and as the rpms come back down the car stalls. Had a few times where ill just be stopped at a light in neutral and the car dies! Been waiting a week for them to get back to me which is mildly frustrating
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 04-22-2023, 12:58 AM   #4
Vangfrs
Drives: Argento Frs
Any update? Been tuning car recently and first time happened 4/18 coasting in neutral car almost stalls out, second time 4/21 car dies at light in neutral.
Vangfrs is offline   Reply With Quote
Old 04-25-2023, 08:05 AM   #5
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
is your car relearning idle after the tune?
I recently replaced my battery and my idle was all over the place (Stage 2+ tune), stalled it as well. after a couple of hours driving everything went back to normal - no more erratic idle.
found this:
https://www.ft86club.com/forums/showthread.php?t=152064
sneaky_pete is offline   Reply With Quote
Old 04-26-2023, 11:41 PM   #6
Vangfrs
Drives: Argento Frs
Was running oft for a while and then DT and never experienced anything like it so kind of freaked me out. I figured it was relearning but it happened two different days so kind of spooked me. After a few more days of driving things seem normal now, and tuner also said it was normal as you stated about ecu relearning, so hopefully thats it.
Idle drops when clutch pushed in and car dies? FRSFather Issues | Warranty | Recalls / TSB 8 10-03-2018 02:18 PM
Frs low idle dip and dies multiple times in a row Dogster70 Issues | Warranty | Recalls / TSB 7 11-17-2017 06:44 PM
car dies when car is put in neutral aquaman Software Tuning 7 06-06-2017 09:21 PM
86 dies at stops Saviorself Issues | Warranty | Recalls / TSB 9 08-05-2016 04:00 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 04:28 PM
