Old 08-04-2016, 07:45 PM   #1
Saviorself
Saviorself's Avatar
Drives: 13' BRZ
86 dies at stops
at times when I'm driving I'm about to approach an intersection so I put her in neutral and she turns off! Most frequently when the AC is on Max. Could it be that she needs a aftermarket alternator or battery? When she got the turbo kit she also had other electronics installed.
Saviorself is offline   Reply With Quote
Old 08-04-2016, 08:31 PM   #2
Doubt it is alternator or battery making it stall. If the power was down that far it shouldn't start again. Not throwing a CEL?
Old 08-04-2016, 08:37 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You need to find out what is failing- is it fuel or spark? Use Torque Pro to watch fuel pressure and system voltage. Don't guess. Don't start throwing parts at it. Figure out what's wrong, WHY it's wrong and fix it right the first time.
Old 08-04-2016, 10:34 PM   #4
swarb
http://www.ft86club.com/forums/forumdisplay.php?f=72
check the first two sticky threads near the top.
Old 08-05-2016, 07:19 AM   #5
steve99
make sure if your mid 2013 or earlier your on latest ecu firmware should be B01C or D if your auto.
if its just started doing it check for air\boost leaks and exhaust leaks, have a look at your ltft if its over 10% theirs likely a leak.
of its done it since turbo install, tune likely needs looking at
Old 08-05-2016, 07:30 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Seeing as your boosted, personally, I would start with the tune.
Old 08-05-2016, 09:49 AM   #7
FX86
i always come into these threads thinking the person is having issues while stock but then they say they got a turbo kit installed or some other major modification and i think to myself well there is your problem
Old 08-05-2016, 02:47 PM   #8
humfrz
Yep, that's the way my mind works also ........
humfrz
Old 08-05-2016, 03:09 PM   #9
humfrz
At least this guy said he had turbo up front. Much worse when we are 3 pages and 50 responses in and then they say "oh and by the way I forgot to mention I have 2% of the stock parts left on my car does that make a difference?"
Old 08-05-2016, 04:00 PM   #10
shellslinger
Drives: Whiteout FRS
Bruh you just don't get it. What difference does it make if I swapped a Ferrari v24 engine in my FRS and slap on a supercharger and turbocharger...its not my fault that the car wont run LOL
shellslinger is offline   Reply With Quote
Scion DIES - DO NOT CARE! FRSbestSportCarEver Scion FR-S / Toyota 86 GT86 General Forum 25 02-12-2016 04:51 PM
Car dies immediately Snyperiflex Issues | Warranty | Recalls / TSB 6 02-08-2016 02:24 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 04:28 PM
WWE Hall of Famer Dies White64Goat Off-Topic Lounge [WARNING: NO POLITICS] 0 07-31-2015 07:48 PM
Does anyone have their OEM bump stops that they're not using? CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-05-2014 09:02 PM
