building life
Drives: Raven Black, 6MT
Car dies after 15-20 minutes?
Well, I just got my car turbo'd(installed myself with the instructions i got emailed), with the FBM base kit with the GT2871 and their base map tune..
Problem is when the car runs till its warmed all the way up and runs for about 20+ minutes after it dies.. and when i try to start it back up it has a rough time, starts up after 2-3 times but than when i give it gas it chokes and starts dying. if i don't give it gas it idles fine, but dies after 10 minutes again. if i give it gas it chokes and starts dying.. what can it be ?!? also no codes beside P0441 is thrown and traction control light is on |
Drives: 2014 Whiteout M/T
Sounds like you should keep trying to start it over and over again. It should eventually pull through!
building life
Drives: 2015 WRX
Unfortunately, instead of being helpful the guy you quoted decided sarcasm was the best choice for a response. While it was funny for the majority of readers, it obviously isn't very helpful to you.
My suggestion would be to get it tuned as a base tune isn't intended to be run daily. Sure its supposed to be safe, but obviously you are having issues with it. Get it tuned and your problems should be fixed. |
And/or have a professional install/tuner shop handle it all next time. Mostly so you don't brick your fa20 like so many people have before you. Don't be cheap and do it right the first time.
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
Need a new tune. Search HRI tuning on Facebook which is the best tuner for this platform, specially regarding the most important part, drivability.
building life
hmm I'll re flash my ecu again, if it doesn't fix it I'll look for a local tuner or talk to fullblown motorsports again
Sent from somewhere |
Reverse Burnouts
Drives: 2013 Argento FRS
vacuum leak? just throwing a suggestion out there some of the rubber hoses in the vacuum system seems to be a small but annoying problem with boosted 86's. dont remember which ones but a quick search on the forums might help
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#9 | |
building life
I'll keep searching around. Thank you Sent from somewhere |
#10 |
Drives: 2010 WRX (sold) 2013 brz
I believe that it's the hoses underneath the intake manifold that seem to fly off under high boost. Usually it's not a sudden problem though. I know when I took off one of my vacuum lines it's very noticeable. Usually the engine struggles to run even at idle.
#11 | |
building life
I checked all the hoses underneath.. I have them clamped on also Sent from somewhere |
#12 | |
Check all hoses and ones on evap canister, check fuel cap is tight, clear the code and see if it returns. you should not be driving on a "base map" they are just to get the car going or drive it a short distance at low rpm to tuner for proper tune. |
#13 |
building life
Update, the car started fine this morning on a cold engine. but when you turn on ignition "on" I didn't hear the fuel pump or anything go. but I don't see how that would make the car choke & die when I give it gas..
#14 |
Sounds like you got the fuel pump install wrong or a bad fuel pump.
There's a number of O-rings that need to be stacked correctly, and the fuel lines inside the canister can get crimped if the assembly isn't put together juuuust right. The fuel pump that came with my FB kit also would stop working intermittently, like you are describing how your car runs. Sometimes it would start and run fine, then 10-15 minutes in it would die. After a while, it would then work again. Switched to a different fuel pump (DW) and all is good now. Check your fuel pump, check your fuel pressure. |
| P087 Code and Car Dies, EcuTek Tuned, FI---Help! | kmbkk | Software Tuning | 34 | 04-05-2014 10:53 PM |
| Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED | learnerspermit | Issues | Warranty | Recalls / TSB | 38 | 11-06-2013 02:51 PM |
| Famous Giorgi Tevzadze dies in Car accident | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 06-25-2013 01:28 PM |
| Cape Town Man Dies after Crashing Toyota 86 | light | AFRICA | 20 | 05-10-2013 04:41 PM |
| Toyota 86 in 10 minutes. | KKaWing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 03-28-2013 09:06 PM |
