Old 10-03-2018, 01:37 PM   #1
FRSFather
Drives: Silver 10 series
Idle drops when clutch pushed in and car dies?
2013 FR-S 54,000 miles. The car starts and idles fine, but when I’m driving and coming up to a stop light, I push in the clutch and then the rpms drop and car dies. It starts right back up. But when the clutch is pushed the rpms drop, and about 50% of the time the car will die. Does anyone know what is causing this? Does this have to do with that cam sensor in the sticky section?
FRSFather is offline   Reply With Quote
Old 10-03-2018, 01:39 PM   #2
tomm.brz
Drives: brz 2017 hksv2
stock ecu?
Old 10-03-2018, 01:45 PM   #3
ermax
ermax's Avatar
There were some idle improvements made in ZA1JB01C but even then the idle dips frequently after an ECU reset. Did you happen to replace your battery or have your battery disconnected? If so the ECU resets and it takes about 200miles to finish it's learning phase and the idle tends to suck until it's done.
If you don't have the latest flash then you may want to go to a dealer and see if they will update it for you or maybe find someone from the community in your area that will flash it for you.
Old 10-03-2018, 01:59 PM   #4
FRSFather
Yes stock ecu. We changed the battery last summer so we have over 200 miles on it. Is that ecu flash something they’ll do for free or is it considered some kind of service? Speaking of batteries this is a 1 year old battery, and it keeps dropping charge when it sits overnight. When it’s running, it’s about 14.4 volts so I believe the alternator is doing it’s job, is there a chance the battery is bad already? I can take it back to Walmart if I have to.
Old 10-03-2018, 02:05 PM   #5
Did it do this before the TOB change?
ermax (10-03-2018)
Old 10-03-2018, 02:09 PM   #6
ermax
ermax's Avatar
I doubt they would flash it for free. If you were within 36k they would do it for free because there is a TSB for it. It is a very simple task that only takes 5mins or so. But pairing new keyfobs is also a simple task which takes even less time but that doesn't stop them from charging obscene amounts to do it.
I would think that if your battery is capable of cranking the car then it's capable of keeping power to the ECU while the car isn't running. It's hard to say though. The official Toyota diagnostics software (Techstream) can tell you how many miles you have gone since the last ECU reset. Maybe a generic OBD2 scanner could also read this. If so, maybe an autoparts store could plug in and check this for you for free.
How is your throttle response right now? After a reset I have a hard time starting off smoothly because the throttle response is very inconsistent.
Old 10-03-2018, 02:12 PM   #7
FRSFather
Yes that’s when I noticed it, but it’s my daughters car. She said it’s been doing that for a while. It seems like it has always dipped wen the clutch is pressed in, but I don’t recall it ever dying from the dip in rpm. I found this online, this was published in 2013 same year as the car, I wonder if the car was made before or after this publishing. Maybe it is the ecu.
http://www.ft86club.com/forums/attac...1&d=1386706237
Old 10-03-2018, 02:14 PM   #8
FRSFather
Throttle response is great.
Old 10-03-2018, 02:18 PM   #9
ermax
ermax's Avatar
That is the TSB I was referring to. I got my 2013 used last year with 82K on it and it was still on the original software which didn't have the idle fix or the DI seal fix. My car would dip low enough to shut off too. I ordered a Tactrix cable the first week of ownership because I wanted to be sure I had the DI seal fix applied to my car. Even on B01C my idle dips but never enough to shut off. It also oscillates a lot at idle.
The Following User Says Thank You to ermax For This Useful Post:
FRSFather (10-03-2018)
Rattle at idle when clutch engaged in netural shu5892001 Issues | Warranty | Recalls / TSB 8 07-07-2018 08:03 PM
Frs low idle dip and dies multiple times in a row Dogster70 Issues | Warranty | Recalls / TSB 7 11-17-2017 06:44 PM
Clutch winning and idle issue with clutch zackegle Issues | Warranty | Recalls / TSB 13 12-05-2016 10:38 AM
Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix Pneub Engine, Exhaust, Transmission 11 08-05-2016 10:29 AM
Idle dipping when the clutch is depressed tylerdone86 Issues | Warranty | Recalls / TSB 8 06-03-2016 09:13 PM
