Drives: 2013 Automatic Scion FRS
I recently installed Tsudo UEL headers onto my car, after a couple of weeks I got a CEL and traction light. The code is P0171, I've replaced my fuel ratio sensor and cleaned the throttle body. Can't seem to figure out what wrong. I also made sure to get an OFT2 tune with the headers as well.
#2 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Maybe if the car was slipping with the small increase in power. Maybe caused by the tune but both are unlikely. CEL might be from the tune. Also might be from the TCS light. |
ProCrastinationConsultant
you've got 2 separate problems. i would investigate the engine code first.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Spuds (02-20-2023), x808drifter (02-21-2023) |
Drives: Crapcan
Traction light usually comes on with CEL. P0171 is a lean code. Check your header install for exhaust leak first.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (02-20-2023) |
Drives: FR-S,GTI
Yeah if you have multible CEL's, the traction light comes on too.
The Dictater
Drives: '13 Red Scion FRS
Do you know how to log or look at live engine parameters with your OFT? That would help.
Also, what tune did you load to the ecu?
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
Drives: 2014 Scion FR-S
P0171 turns on both traction light and CEL. Seems like an exhaust leak to me.
| The Following User Says Thank You to Jollibee86 For This Useful Post: | Tcoat (02-21-2023) |
#8 | |
It is explained in the owners manual.
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (02-22-2023) |
who has time to read that?!?
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
| Check Engine light and Traction Control Light | JeRM | Issues | Warranty | Recalls / TSB | 25 | 06-02-2023 09:00 PM |
| Check engine light and Traction light on. | ser1alchill3r | Engine, Exhaust, Transmission | 20 | 08-30-2020 03:57 AM |
| Abs and traction light no tailights replaced brake light switch now what? | Brzlimited661 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-28-2018 06:04 PM |
| traction light, engine light = cam sprocket , ecu | nivek111070 | Issues | Warranty | Recalls / TSB | 27 | 03-13-2016 09:28 AM |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 07:37 AM |
