Drives: 2014 subaru brz satin pearl white
Check engine light and Traction light on.
My 2014 Subaru Brz limited has only 1 mod and it's a drop in k&n air filter. After installing the filter I drove the car for a week without any problems and then I had my check engine light and traction light on on my way back to work. I got an OBD scanner and got the following codes:
P0171 - System too lean Bank 1 P117B P1170 I took out the filter and reassembled it into the air box yesterday and also cleaned the maf sensor with CRC maf sensor cleaning liquid. Disconnected the battery and reset the ECU. Took it for a test drive and no problems. Today when I started the car and before going a mile the check engine light and traction light is back on. Traction light goes away after some time and comes back again. Check engine light remains on and stays on. What do I do to fix this? I have no idea what's happening as I'm a noob to the car scene. If anybody can advise that would be great. I live in the waterloo region in canada and would love to take the car to a good mechanic in the region if anybody can suggest one for me please. |
Wheels for Brains
Try putting the stock air filter back in and see? Did you knock something loose? Any images of the engine bay?
All seem like fuel injector codes. |
Hello ser1alchill3r and welcome to our forum -
![]() It appears that you have done the easy things. Considering your limited knowledge of that car, I would recommend that you take it into a shop and have them fix it. Meanwhile you may wish to look up those codes on line and follow their leads to look for a bad connection that would effect an injector. I hope you get er fixed soon. |
Thanks @humfrz.
I will be getting a new stock air filter tomorrow and will reset the ecu again with stock air filter and see what happens. |
How many k? How long have you had the car?
113000 kms. I bought the car recently when it was at 100000.
#7 | |
Drives: 2013 FRS
Ignition coil, most likely cyl #1
2013 FRS - JRSC CARB
"Use all of the track" they say |
Drives: '14
Hello, why do you think it's the coil pack? OP seems to have his CEL on right after changing his air filter, so it must mean that his air filter is the problem, no? I'm not trying to be rude, I am genuinely curious because I have the same problem
#10 | |
Wheels for Brains
If the symptoms are known, it's worth checking. At 100k km, may be spark plugs based on service internal. Though if the car was always NA, spark plugs usually are pretty clean. |
#11 |
I have no idea what's going on. So I'm going to take it to a subie mechanic tomorrow. Hopefully it's nothing bad. I'll keep you guys posted. Thanks a lot for pitching in with your honest opinions.
#12 |
Señor Member
A very quick search on those codes came up with the below thread among others. Sounds like it is an air leak somewhere. Did you undo any hose clamps when changing the filter?
There is also someone who's battery died and the low voltages were tripping codes like that. More likely an air leak in your intake tho. https://www.ft86club.com/forums/show....php?p=2128963
1974 TA22 Celica
2013 86 GT |
#13 | |
Drives: 2013 FRS
The behavior of warning lights and obdii codes. Yes I agree it’s not obvious and there are certainly other possibilities ( for a bank to run lean, can be too much air or too little fuel in normal thinking, I think it had to do with short/long fuel trim and in a particular situation that our car seem to get into. The problem completely went away after replace cyl1 coil, in my particular case. Ymmv Ps I too checked for leaks, fuel supply etc, until noticed a thread where cyl1 coil often fail on these cars prob due proximity to exhaust header.
#14 |
I booked an appointment on Thursday with the mechanic. I dont think it's the coul pack cos I dont have a single misfire as per the obd scanner. However my LTFt and STFT are off the charts.
| Tags |
| check engine light, k&n air filter, maf sensor, o2 sensor, traction control light |
| Check Engine light and Traction Control Light | JeRM | Issues | Warranty | Recalls / TSB | 25 | 06-02-2023 09:00 PM |
| Help needed! Check engine light after weird traction lights. | dillanp86 | Engine, Exhaust, Transmission | 3 | 12-08-2016 09:17 AM |
| traction light, engine light = cam sprocket , ecu | nivek111070 | Issues | Warranty | Recalls / TSB | 27 | 03-13-2016 09:28 AM |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 07:37 AM |
| First Check Engine Light and Traction control | QFry | Issues | Warranty | Recalls / TSB | 26 | 10-04-2014 11:27 PM |
