Drives: 2014 brz limited
Abs and traction light no tailights replaced brake light switch now what?
Ok so i had the common brake light switch failure symptoms of abs light and traction control light and no brake lights. I checked all the fuses and replaced the switch with a new oem part. And it still doesn't work. Also tried disconnecting battery. Still no luck. Any suggestions? Do you need to adjust it a certain way or a scan tool to reset light and have brake lights working again? It is a 14 brz limited 6 speed thanks.
All stock?
Yes it is
#4 | |
If so, manually work the switch and see if the brake lights come on. If they do, I reckon the switch isn't positioned correctly. HA .....HA ...... I beat @Tcoat to the trouble shooting post ....... ![]() humfrz |
Will just pressing the button on the switch be enough for the brake lights to come on if it is the position of the switch or do i also need to press the brake pedal.
#6 | |
I reckon the brake pedal is activating the switch ...... how else would the lights know to come on ... ?? Maybe ol @Tcoat will be along to clarify the situation. I just had a grueling Walmart experience ...... and I need a nap ...... ![]() humfrz |
| Brake Light Switch Fault - TSB Fix | Dezoris | Issues | Warranty | Recalls / TSB | 4 | 01-07-2025 10:13 AM |
| No brake light, dash showing abs and traction | ducky369 | Issues | Warranty | Recalls / TSB | 8 | 04-11-2017 03:16 PM |
| FS: OEM Headlights, OEM Tailights, OEM third brake light, Valenti Rear Taillights. | Stevenchoi5 | Exterior Parts (Aero, Lighting, Etc.) | 18 | 02-27-2017 12:59 AM |
| ABS, Traction control and brake light??? | JMoore412 | Issues | Warranty | Recalls / TSB | 18 | 08-20-2014 05:09 PM |
| Traction control, abs and brake light all on? | JMoore412 | Issues | Warranty | Recalls / TSB | 0 | 08-12-2014 07:27 PM |
