Old 02-19-2023, 03:03 AM   #1
red_frs
red_frs's Avatar
Drives: 2013 Automatic Scion FRS
Exclamation CEL and Traction light
I recently installed Tsudo UEL headers onto my car, after a couple of weeks I got a CEL and traction light. The code is P0171, I've replaced my fuel ratio sensor and cleaned the throttle body. Can't seem to figure out what wrong. I also made sure to get an OFT2 tune with the headers as well.
red_frs is offline   Reply With Quote
Old 02-19-2023, 04:38 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Everything bolded has zero to deal with a TCS light.
Maybe if the car was slipping with the small increase in power.
Maybe caused by the tune but both are unlikely.
CEL might be from the tune.
Also might be from the TCS light.
Old 02-19-2023, 09:16 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
you've got 2 separate problems. i would investigate the engine code first.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Spuds (02-20-2023), x808drifter (02-21-2023)
Old 02-20-2023, 10:37 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Traction light usually comes on with CEL. P0171 is a lean code. Check your header install for exhaust leak first.
Spuds (02-20-2023)
Old 02-20-2023, 12:23 PM   #5
WNDSRFR
Drives: FR-S,GTI
Yeah if you have multible CEL's, the traction light comes on too.
Old 02-20-2023, 05:35 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Do you know how to log or look at live engine parameters with your OFT? That would help.
Also, what tune did you load to the ecu?
Also: "Build Thread"
Old 02-21-2023, 07:11 PM   #7
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
P0171 turns on both traction light and CEL. Seems like an exhaust leak to me.
Jollibee86 is offline   Reply With Quote
The Following User Says Thank You to Jollibee86 For This Useful Post:
Tcoat (02-21-2023)
Old 02-21-2023, 09:02 PM   #8
Many codes turn both lights on. It indicates that "limp mode" is active. It will also reduce the revs it will let you do and cruise won't work.
It is explained in the owners manual.
Spuds (02-22-2023)
Old 02-21-2023, 11:04 PM   #9
soundman98
soundman98's Avatar
who has time to read that?!?
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Spuds (02-22-2023), villainous_frx (02-21-2023), x808drifter (02-24-2023)
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 09:00 PM
Check engine light and Traction light on. ser1alchill3r Engine, Exhaust, Transmission 20 08-30-2020 03:57 AM
Abs and traction light no tailights replaced brake light switch now what? Brzlimited661 Scion FR-S / Toyota 86 GT86 General Forum 5 01-28-2018 06:04 PM
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 09:28 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
