Drives: 2013 WRB BRZ
Brz Fueling Issues/AFRs all over the place
Hey Everyone,
A little back story of the car. Its a 2013 and I turboed the car 2-3 years ago and it has 60k miles on it now. I haven't done any maintenance on it recently at all. I have looked through a lot of the forums about fuel trims and other fueling issues but my issues never seem to be quite the same so I thought I would make a post on my own. Ive had this issue for a few months now but it has slowly gotten worse over the past couple weeks. First while cruising, the car would randomly go very rich (10-12 afr) and would bog/ almost die. this would happen for about 2 seconds then would go completely back to normal. I can never recreate it and it seems to be very random. At first this would happen every few weeks now its more like every few days and last 5ish seconds + sometimes it actually dies. The AFRs are all over the place even while normal driving. They fluctuate between 11-17 while just cruising. When I start the car and idle the AFRs also jump around and sometimes the car dies. I did a data log and my fuel trims are definitely off and have a very wide range. I will attach a couple of the logs. Anyone have any ideas on what part has failed? also let me know if you need anymore information. Thank you! |
| Tags |
| fueling, issues, runs bad |
| TC messing with fueling | dholloway543 | Software Tuning | 31 | 08-06-2020 10:13 AM |
| Why AFRs and power change after first dyno run? | mkodama | Engine, Exhaust, Transmission | 11 | 09-16-2017 01:14 PM |
| When to upgrade fueling? | SirSpectre | Forced Induction | 5 | 10-06-2015 11:56 AM |
| Fueling Issue | Simisimi | Issues | Warranty | Recalls / TSB | 5 | 12-22-2014 05:17 PM |
| How closely should AFRs be monitored when not WOT? | post_break | Software Tuning | 23 | 06-10-2014 10:36 PM |
