Old 10-02-2015, 05:33 PM   #1
SirSpectre
Drives: 2013 Hot Lava FRS
When to upgrade fueling?
I am a few weeks away from installing my turbo kit. It did not come with fueling upgrades, it said its not needed. I am getting some conflicting reports with this now.
Aim is 275 whp on 93 octane. I've been told stock is fine. I've been told upgrade fuel pump. I've been told upgrade injectors and pump, ive been told upgrade injectors.
Obviously I have no idea. What say you turbo guys? I really don't care either way, I just don't want to hop on the dyno for a tune and the guy says "need more fuelz!! lulz" I just don't want to do the effort if I don't need to.
Thanks!
SirSpectre is offline   Reply With Quote
Old 10-02-2015, 06:18 PM   #2
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Could you help us by mentioning which turbo kit you bought? Some may need the extra fuel capacity for your goals, but it's not likely. I am not a turbo owner, but I've been following the FI kits available.
Trefoil is offline   Reply With Quote
Old 10-02-2015, 09:36 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If your goal is more power than the kit offers then it would be a good idea once your over the 300hp mark.
If all you want is just added power any kit will give you, you'll be fine.
Coming from my experience from turbo mr2. Our stock turbo fuel pumps are good up to 380hp.
Old 10-02-2015, 09:36 PM   #4
BRZ'13
BRZ'13's Avatar
Drives: subaru
@ 275 with 93 your fine with stock fuel mods. Close to the limit but fine. At the bare minimum uprade the fuel pump. Injectors are fine till 300
BRZ'13 is offline   Reply With Quote
The Following User Says Thank You to BRZ'13 For This Useful Post:
SirSpectre (10-06-2015)
Old 10-02-2015, 10:14 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That is up to the tuner method of tuning. By increasing the use of DI injectors, close to 400 whp have been reached on stock system with 93 pumpgas. I don't recommend over taxing the DI system.
But regardless, rule of thumb is while on pumpgas no need to upgrade anything. The limits of pumpgas are around 350 whp and 12 psi.
Once you go E85, upgrade injectors and pump.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Cessblood (10-06-2015), SirSpectre (10-06-2015)
Old 10-06-2015, 11:56 AM   #6
SirSpectre
Awesome thanks!
I just picked up a fuel pump. We'll try the injectors see what can happen with them. My tuner said with this kit he starts to see rail pressure drops at about 270 hp.
I bit the bullet and did what everyone was thinking...the CX racing kit. I'll be posting a review on it in a bit. tl;dr version so far, damn high quality exhaust and IC pipes. MAF in kind of a funky spot. Wastegate and blow off are ebay specials. Replaced instantly with Tial and true Greddy bov. Not even messing around with those.
The Following User Says Thank You to SirSpectre For This Useful Post:
Sportsguy83 (10-07-2015)
MAF Scaling - Open/Closed Loop Fueling info steve99 Software Tuning 653 07-10-2024 04:25 AM
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 08:04 PM
Transient Fueling ~ DI/PI Kodename47 Software Tuning 2 07-17-2015 06:27 AM
Fueling Issue Simisimi Issues | Warranty | Recalls / TSB 5 12-22-2014 05:17 PM
Re-fueling Timing and Amount Chad86 Scion FR-S / Toyota 86 GT86 General Forum 26 03-15-2014 02:03 PM
